[Geomoose-users] Problem with footer in select.php
    Anderson, Dean
    anderson.dean at co.polk.or.us
    Fri Aug 31 06:42:40 PDT 2012
That would be strange and different then the other itemquery file is
relative to the map file
'itemquery' 'templates/search_result.html'
On Thu, Aug 30, 2012 at 5:11 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Dean,
>   I think the path is relative to the PHP folder since the select service
> target is select.php.
> Best Regards,
> Brent Fraser
> On 8/30/2012 2:56 PM, Anderson, Dean wrote:
> So...
> Now I am testing the itemquery stuff for query.php.  I made the header and
> footer work fine using the settings.ini file (thanks for that suggestion
> and am testing it pretty well).  However, I think I should also be able to
> make this work using the reference in the parcels.map file with something
> like...
> 'itemquery_header' 'templates/header.html'
> 'itemquery_footer' 'templates/footer.html'
> Unfortunately this does not seem to work.  Am I messing up?  When I have
> the files in the itemquery directory (as referenced in the settings.ini)
> file they work fine. However, when I have them in templates directory for
> parcels they do not work at all.  I am not sure what is up.
> I am trying to finish this up to complete my query customization test and
> documentation.
> Any ideas??
> Dean
> On Thu, Aug 30, 2012 at 11:55 AM, Anderson, Dean <
> anderson.dean at co.polk.or.us> wrote:
>> Brent
>> Adding <!-- MapServer Template --> to my HTML fixed it!
>> I am aware of the stuff in the settings.ini file and had that covered. I
>> am testing the customization part for the select tool and wanted to test
>> having a layer specific footer.
>> THANKS!
>> Dean
>> On Thu, Aug 30, 2012 at 11:45 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>>  Dean,
>>>   Don't forget there's an [Identify] section in the settings.in for
>>> global header and footer.
>>> And your footer.html may need Mapserver's magic string at the top:
>>> Best Regards,
>>> Brent Fraser
>>>  On 8/30/2012 11:29 AM, Anderson, Dean wrote:
>>>  I am not sure if this is a bug and I need to verify before submitting
>>> ticket.  I am not able to display a footer using the select service
>>> (select.php).  This is what I did..
>>> 1. Created a "select_footer.html" file in the
>>> maps\demo\parcels\templates directory.
>>> 2. Added the reference to the Metadata section in parcel.map
>>> 'select_footer' 'templates/select_footer.html'
>>> 3. Cleared cache and ran demo - not display of footer stuff.
>>> 4. Checked the select.php to see if I had my reference for the footer is
>>> correct.  Found the line:
>>> if($layer->getMetadata('select_footer')) {
>>>   $layer->set('footer', $layer->getMetadata('select_footer'));
>>> Based on some simple tests it appears my file is being loaded in
>>> select.php, so I think it is being referenced correctly but does not
>>> display.  Any ideas on how to make this work would be much appreciated.  It
>>> is the last test I need to do in customizing the app for select.
>>>  Dean R Anderson
>>> IT Director
>>> Polk County
>>>  _______________________________________________
>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Dean R Anderson
>> IT Director
>> Polk County
> Dean R Anderson
> IT Director
> Polk County
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120831/4bb06c0f/attachment-0001.html>
More information about the Geomoose-users
