[Geomoose-users] Problem with footer in select.php
Brent Fraser
bfraser at geoanalytic.com
Fri Aug 31 08:13:11 PDT 2012
Hmm. I must have been confused; sorry for the misdirection.
I grepped the PHP folder for "itemquery" and found only:
query.php:408: $CONFIGURATION['query_header'] =
$CONFIGURATION['itemquery_header'];
query.php:412: $CONFIGURATION['query_footer'] =
$CONFIGURATION['itemquery_footer'];
which references the entries in the settings.ini. So I'd guess there
is no ability to have settings in the mapfile...
Best Regards,
Brent Fraser
On 8/31/2012 7:42 AM, Anderson, Dean wrote:
> That would be strange and different then the other itemquery file is
> relative to the map file
> 'itemquery''templates/search_result.html'
> On Thu, Aug 30, 2012 at 5:11 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> Dean,
> I think the path is relative to the PHP folder since the select
> service target is select.php.
> Best Regards,
> Brent Fraser
> On 8/30/2012 2:56 PM, Anderson, Dean wrote:
>> So...
>> Now I am testing the itemquery stuff for query.php. I made the
>> header and footer work fine using the settings.ini file (thanks
>> for that suggestion and am testing it pretty well). However, I
>> think I should also be able to make this work using the reference
>> in the parcels.map file with something like...
>> 'itemquery_header' 'templates/header.html'
>> 'itemquery_footer' 'templates/footer.html'
>> Unfortunately this does not seem to work. Am I messing up? When
>> I have the files in the itemquery directory (as referenced in the
>> settings.ini) file they work fine. However, when I have them in
>> templates directory for parcels they do not work at all. I am
>> not sure what is up.
>> I am trying to finish this up to complete my query customization
>> test and documentation.
>> Any ideas??
>> Dean
>> On Thu, Aug 30, 2012 at 11:55 AM, Anderson, Dean
>> <anderson.dean at co.polk.or.us
>> <mailto:anderson.dean at co.polk.or.us>> wrote:
>> Brent
>> Adding <!-- MapServer Template --> to my HTML fixed it!
>> I am aware of the stuff in the settings.ini file and had that
>> covered. I am testing the customization part for the select
>> tool and wanted to test having a layer specific footer.
>> THANKS!
>> Dean
>> On Thu, Aug 30, 2012 at 11:45 AM, Brent Fraser
>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>> Dean,
>> Don't forget there's an [Identify] section in the
>> settings.in <http://settings.in/> for global header and
>> footer.
>> And your footer.html may need Mapserver's magic string at
>> the top:
>> Best Regards,
>> Brent Fraser
>> On 8/30/2012 11:29 AM, Anderson, Dean wrote:
>>> I am not sure if this is a bug and I need to verify
>>> before submitting ticket. I am not able to display a
>>> footer using the select service (select.php). This is
>>> what I did..
>>> 1. Created a "select_footer.html" file in the
>>> maps\demo\parcels\templates directory.
>>> 2. Added the reference to the Metadata section in
>>> parcel.map
>>> 'select_footer' 'templates/select_footer.html'
>>> 3. Cleared cache and ran demo - not display of footer
>>> stuff.
>>> 4. Checked the select.php to see if I had my reference
>>> for the footer is correct. Found the line:
>>> if($layer->getMetadata('select_footer')) {
>>> $layer->set('footer',
>>> $layer->getMetadata('select_footer'));
>>> Based on some simple tests it appears my file is being
>>> loaded in select.php, so I think it is being referenced
>>> correctly but does not display. Any ideas on how to
>>> make this work would be much appreciated. It is the
>>> last test I need to do in customizing the app for select.
>>> Dean R Anderson
>>> IT Director
>>> Polk County
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Dean R Anderson
>> IT Director
>> Polk County
>> Dean R Anderson
>> IT Director
>> Polk County
> Dean R Anderson
> IT Director
> Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120831/4bf8ac7f/attachment.html>
More information about the Geomoose-users
