[Geomoose-users] Unable to implement select feature service
Eli Adam
eadam at co.lincoln.or.us
Mon Dec 10 10:42:48 PST 2012
> Thanks a lot for your help. I was able to view my layer when I had layer source as *“Data/**Lease/Lease*” just that all my services besides “Identify” didn’t work. (Identify worked, but got error when trying to *generate report*, the error was Error: Unable to load php/feature_report.php status:500****
> _28d()dojo.js (line 14)****
> _286/func()dojo.js (line 14)****
> _286()****
> here is what I just did for fixing the select feature service:****
> **1. **I just set up firebug and found out that the service was
> looking for my lease folder under C:\ms4sw\apps\geomoose2\maps.****
> **2. **I then move the whole “Data” folder under
> “C:\ms4sw\apps\geomoose2\maps\” and modify the “mapbook.xml” for proper
> path.****
> **3. **The layer show up find and the select service seems to go
> one step further: It returned as “no feature found” even I am sure there
> should be something.
If Lease is a point dataset, you may want to add TOLERANCE 50 in your map
file as described in this previous list post,
http://lists.osgeo.org/pipermail/geomoose-users/2012-September/004341.html
Eli
> **4. **The mapfile that generated for the select service in ms_tmp
> indicated the projection as ****
> PROJECTION****
> '+init=epsg:4326'****
> END****
> My initial projection for the layer was 'init=epsg:32040',
> the mapbook.xml projection was EPSG:3857****
> Do you have any advice?****
> Thanks for any inputs!****
> Joyce****
> Statement of Confidentiality:
> This message may contain information that is privileged or confidential.
> If you receive this transmission in error, please notify the sender by
> reply e-mail and delete the message and any attachments.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121210/ce142880/attachment.html>
More information about the Geomoose-users
