[Geomoose-users] Unable to implement select feature service
Lin, Joyce
Joyce.Lin at pxd.com
Mon Dec 10 11:28:54 PST 2012
It's actually a polygon file. I did change the tolerance to 50 but no luck on that....
Thanks still!
Joyce
Sent: Monday, December 10, 2012 12:43 PM
To: Lin, Joyce
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Unable to implement select feature service
Thanks a lot for your help. I was able to view my layer when I had layer source as "Data/Lease/Lease" just that all my services besides "Identify" didn't work. (Identify worked, but got error when trying to generate report, the error was Error: Unable to load php/feature_report.php status:500
_28d()dojo.js (line 14)
_286/func()dojo.js (line 14)
_286()
here is what I just did for fixing the select feature service:
1. I just set up firebug and found out that the service was looking for my lease folder under C:\ms4sw\apps\geomoose2\maps.
2. I then move the whole "Data" folder under "C:\ms4sw\apps\geomoose2\maps\" and modify the "mapbook.xml" for proper path.
3. The layer show up find and the select service seems to go one step further: It returned as "no feature found" even I am sure there should be something.
If Lease is a point dataset, you may want to add TOLERANCE 50 in your map file as described in this previous list post, http://lists.osgeo.org/pipermail/geomoose-users/2012-September/004341.html
Eli
4. The mapfile that generated for the select service in ms_tmp indicated the projection as
PROJECTION
'+init=epsg:4326'
END
My initial projection for the layer was 'init=epsg:32040', the mapbook.xml projection was EPSG:3857
Do you have any advice?
Thanks for any inputs!
Joyce
Statement of Confidentiality:
This message may contain information that is privileged or confidential. If you receive this transmission in error, please notify the sender by reply e-mail and delete the message and any attachments.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121210/e0fcdf06/attachment-0001.html>
More information about the Geomoose-users
