[Geomoose-users] measure tool geomoose 2.4
Eli Adam
eadam at co.lincoln.or.us
Mon Jul 2 08:16:48 PDT 2012
Radoslav,
Perhaps someone on the email list knows the answer
Eli
On Mon, Jul 2, 2012 at 7:14 AM, Radoslav Melicher
<melicherr at kolektory.cz> wrote:
> Hi, Eli.
> I find out that in my instance of geomoose 2.4 there is a problem with measure tool... The problem is with both distance and area measurement. When I try to use the measure tool it works weirdly. In left bottom corner there is the "ruler" which I use for this. So I try to measure the distance according to this ruler. And when the ruler says some distance should have 100 meters, the measure tool told me its about 66 meters. The same thing is with the area measure tool, it gives me result, and when I compute squareroot from the result I get something about 66 meters. I use meters and I also have it set in mapbook as ground units. In mapbook I use only EPSG:900913 and 4326 system.
> I cannot find the solution in forum and on internet. Maybe, I just didn't make the right query. In that case, I appologize.
> Thanks in advance
> Best Regards
> Radoslav Melicher
More information about the Geomoose-users
