[Geomoose-users] measure tool geomoose 2.4
James Klassen
klassen.js at gmail.com
Mon Jul 2 08:59:44 PDT 2012
Not a complete answer, but a place to start looking:
In terms of the measuring tools, Web Mercator and Lat/Lon are certainly the
most difficult to deal with, especially if you are viewing a large
geographic area as the effective scale changes across the map. If I
remember correctly, in these cases GeoMoose only considers the scale at one
point on the map and applies that scale everywhere. I don't know how the
scalebar is calculated, but it is also subject to the same issue (scale not
constant across map).
On Mon, Jul 2, 2012 at 10:16 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> Radoslav,
> Perhaps someone on the email list knows the answer
> Eli
> On Mon, Jul 2, 2012 at 7:14 AM, Radoslav Melicher
> <melicherr at kolektory.cz> wrote:
> > Hi, Eli.
> > I find out that in my instance of geomoose 2.4 there is a problem with
> measure tool... The problem is with both distance and area measurement.
> When I try to use the measure tool it works weirdly. In left bottom corner
> there is the "ruler" which I use for this. So I try to measure the distance
> according to this ruler. And when the ruler says some distance should have
> 100 meters, the measure tool told me its about 66 meters. The same thing is
> with the area measure tool, it gives me result, and when I compute
> squareroot from the result I get something about 66 meters. I use meters
> and I also have it set in mapbook as ground units. In mapbook I use only
> EPSG:900913 and 4326 system.
> > I cannot find the solution in forum and on internet. Maybe, I just
> didn't make the right query. In that case, I appologize.
> > Thanks in advance
> > Best Regards
> > Radoslav Melicher
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120702/5c10e862/attachment.html>
More information about the Geomoose-users
