[Geomoose-users] Data Projected in wrong area
Joshua Meyer
jmeyer at lcsheriff.com
Thu Jul 12 07:30:33 PDT 2012
I may not totally understand your question. Here is the Projection from one
of the map files.
WEB
METADATA
'ows_title' 'County'
'ows_srs' 'EPSG:102698 EPSG:26998 EPSG:26915
EPSG:4326 EPSG:900913 EPSG:3857'
'ows_enable_request' '*'
END
END
PROJECTION
'init=epsg:26998'
END
I have added the projection to the geomoose.html file.
<script type="text/javascript"
src="projections/EPSG26998.js"></script>
Here is the projection file as I copied off of spatialreference.
Proj4js.defs["EPSG:26998"] = "+proj=tmerc +lat_0=36.16666666666666
+lon_0=-94.5 +k=0.999941177 +x_0=850000 +y_0=0 +ellps=GRS80 +datum=NAD83
+units=m +no_defs";
Deputy Joshua Meyer #198
Lafayette County Sheriff's Department GIS
107 S. 11th Street
Lexington Mo, 64067
Phone: (660) 259-2796 | Fax: (660) 259-2545
Cell: (660) 259-1234
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, July 12, 2012 9:18 AM
To: Joshua Meyer
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Data Projected in wrong area
So what does your Mapserver mapfile contain in terms of projections?
Best Regards,
Brent Fraser
On 7/12/2012 8:08 AM, Joshua Meyer wrote:
> I have performed all those steps. If I leave the projection in
> mapbook.xml as 3857 my data is projected off the coast of Maine and
rotated clockwise.
> The map files I created(modified) are initialized as 26998. The
> settings.ini and mapbook.xml are both 3857. I have changed the
> projection in settings.ini to 26998 and this has no effect on how my data
is projected.
> Joshua Meyer
> From: TC Haddad [mailto:tchaddad at gmail.com]
> Sent: Tuesday, July 10, 2012 3:56 PM
> To: Joshua Meyer
> Make sure to look closely at:
> http://www.geomoose.org/docs/projections.html
> In particular, both parts of Step 2.
> Tanya
> On Tue, Jul 10, 2012 at 12:03 PM, Joshua Meyer <jmeyer at lcsheriff.com>
wrote:
>> I am new to GeoMoose. I have added my data and have it projecting.
>> The data is all NAD_1983_StatePlane_Missouri_West_FIPS_2403_Feet. I
>> looked up the information on spatialreference.com and found I needed
>> EPSG:26998. I added the new EPSG as per the GeoMoose instructions on
>> http://www.geomoose.org/docs/projections.html.
>> My data is being projected over Africa. Does anyone know what I am
>> doing wrong?
>> Thanks,
>> Josh
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
