[Geomoose-users] Data Projected in wrong area
Brent Fraser bfraser at geoanalytic.com
Thu Jul 12 08:04:29 PDT 2012
Joshua,
     From your posts, I assume you want to display the data in EPSG:3857
to allow overlaying your data on to Google/Bing/Yahoo map layers?  And
your data is currently stored in
NAD_1983_StatePlane_Missouri_West_FIPS_2403_ **Feet** which (according
to SpatialReference) is not defined by EPSG, but is defined by ESRI.
EPSG does define the State Plane zone with units of meters, EPSG:26998,
but that won't help.
So the only part of the configuration that needs to define the State
plane zone is in the LAYER's PROJECTION object (it specifies the
coordinate system of the source data).  The MAP's PROJECTION object
needs to define the target coordinate system (EPSG:3857) as mapserver
will handle the re-projection from the source system to the target
system.  And the GeoMoose needs only to be configured for EPSG:3857
since there is no need for it to know about the coordinate system of the
source data.
In your Mapserver map file, the LAYER should have
LAYER
     PROJECTION
         'init=esri:102698'
     END
(note the esri, not epsg as the defining authority).  And the MAP object
should have
MAP
     PROJECTION
         'init=epsg:3857'
     END
Best Regards,
Brent Fraser
On 7/12/2012 8:30 AM, Joshua Meyer wrote:
> I may not totally understand your question.  Here is the Projection from one
> of the map files.
> 	WEB
> 		METADATA
> 			'ows_title' 'County'
> 			'ows_srs' 'EPSG:102698 EPSG:26998 EPSG:26915
> EPSG:4326 EPSG:900913 EPSG:3857'
> 			'ows_enable_request' '*'
> 		END
> 	END
> 	PROJECTION
> 		'init=epsg:26998'
> 	END
> I have added the projection to the geomoose.html file.
> 	<script type="text/javascript"
> src="projections/EPSG26998.js"></script>
> Here is the projection file as I copied off of spatialreference.
> 	Proj4js.defs["EPSG:26998"] = "+proj=tmerc +lat_0=36.16666666666666
> +lon_0=-94.5 +k=0.999941177 +x_0=850000 +y_0=0 +ellps=GRS80 +datum=NAD83
> +units=m +no_defs";
> Deputy Joshua Meyer #198
> Lafayette County Sheriff's Department GIS
> 107 S. 11th Street
> Lexington Mo, 64067
> Phone: (660) 259-2796 | Fax: (660) 259-2545
> Cell: (660) 259-1234
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, July 12, 2012 9:18 AM
> To: Joshua Meyer
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Data Projected in wrong area
> So what does your Mapserver mapfile contain in terms of projections?
> Best Regards,
> Brent Fraser
> On 7/12/2012 8:08 AM, Joshua Meyer wrote:
>> I have performed all those steps.  If I leave the projection in
>> mapbook.xml as 3857 my data is projected off the coast of Maine and
> rotated clockwise.
>> The map files I created(modified) are initialized as 26998.  The
>> settings.ini and mapbook.xml are both 3857. I have changed the
>> projection in settings.ini to 26998 and this has no effect on how my data
> is projected.
>> Joshua Meyer
>> From: TC Haddad [mailto:tchaddad at gmail.com]
>> Sent: Tuesday, July 10, 2012 3:56 PM
>> To: Joshua Meyer
>> Make sure to look closely at:
>> http://www.geomoose.org/docs/projections.html
>> In particular, both parts of Step 2.
>> Tanya
>> On Tue, Jul 10, 2012 at 12:03 PM, Joshua Meyer <jmeyer at lcsheriff.com>
> wrote:
>>> I am new to GeoMoose.  I have added my data and have it projecting.
>>> The data is all NAD_1983_StatePlane_Missouri_West_FIPS_2403_Feet.  I
>>> looked up the information on spatialreference.com and found I needed
>>> EPSG:26998.  I added the new EPSG as per the GeoMoose instructions on
>>> http://www.geomoose.org/docs/projections.html.
>>> My data is being projected over Africa.  Does anyone know what I am
>>> doing wrong?
>>> Thanks,
>>> Josh
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
