[Geomoose-users] requested image size 2.6 vs 2.2
Matej Mailing mailing at tam.si
Wed Oct 3 13:54:47 PDT 2012
I would also be interested in this solution. Currently it seems
tilecache doesn't work - when moving map the surrounding views are
"not loaded". Is this normal behaviour or am I doing something wrong?
Thanks,
Matej
2012/9/24 Mark Volz <MarkVolz at co.lyon.mn.us>:
> Hello,
> GeoMOOSE appears to request a larger image than what was displayed on the map.  This allows for a user to pan around slightly before a new image would need to be requested from the server.  It also makes tilled images appear much faster - since the tiles would start to load before a user could pan to the area.  Is there any way to configure 2.6 so that we can request larger images so that GM 2.6 behaves more like 2.2?
> Thanks
> Mark Volz
> GIS Specialist
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
