[Geomoose-users] requested image size 2.6 vs 2.2
Jim Klassen klassen.js at gmail.com
Wed Oct 3 21:01:50 PDT 2012
You're likely something wrong.  Do you have tiled=true set in the mapbook?
On Oct 3, 2012, at 3:54 PM, Matej Mailing wrote:
> Hi,
> I would also be interested in this solution. Currently it seems
> tilecache doesn't work - when moving map the surrounding views are
> "not loaded". Is this normal behaviour or am I doing something wrong?
> Thanks,
> Matej
> 2012/9/24 Mark Volz <MarkVolz at co.lyon.mn.us>:
>> Hello,
>> GeoMOOSE appears to request a larger image than what was displayed on the map.  This allows for a user to pan around slightly before a new image would need to be requested from the server.  It also makes tilled images appear much faster - since the tiles would start to load before a user could pan to the area.  Is there any way to configure 2.6 so that we can request larger images so that GM 2.6 behaves more like 2.2?
>> Thanks
>> Mark Volz
>> GIS Specialist
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
