[Geomoose-users] requested image size 2.6 vs 2.2
    Matej Mailing
    mailing at tam.si
    Thu Oct  4 05:50:45 PDT 2012
I have type="mapserver" and the path to the mapfile within the file.
Is tiled=true available only for type="wms"? I have output already set
as WMS in the mapfile, can I use it somehow?
Thanks,
Matej
2012/10/4 Jim Klassen <klassen.js at gmail.com>:
> You're likely something wrong.  Do you have tiled=true set in the mapbook?
> On Oct 3, 2012, at 3:54 PM, Matej Mailing wrote:
>> Hi,
>> I would also be interested in this solution. Currently it seems
>> tilecache doesn't work - when moving map the surrounding views are
>> "not loaded". Is this normal behaviour or am I doing something wrong?
>> Thanks,
>> Matej
>> 2012/9/24 Mark Volz <MarkVolz at co.lyon.mn.us>:
>>> Hello,
>>> GeoMOOSE appears to request a larger image than what was displayed on the map.  This allows for a user to pan around slightly before a new image would need to be requested from the server.  It also makes tilled images appear much faster - since the tiles would start to load before a user could pan to the area.  Is there any way to configure 2.6 so that we can request larger images so that GM 2.6 behaves more like 2.2?
>>> Thanks
>>> Mark Volz
>>> GIS Specialist
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
