[Geomoose-users] requested image size 2.6 vs 2.2
Jim Klassen
klassen.js at gmail.com
Thu Oct 4 06:49:55 PDT 2012
Now I am confused. Are you accessing TileCache or MapServer?
Type=wms is preferred in 2.6 over type=mapserver presuming you are accessing Mapserver/WMS.
TileCache/MapCache/OpenStreetMap tiles/etc. would typically use a different type. I don't have my computer in front of me to check which one.
On Oct 4, 2012, at 7:50, Matej Mailing <mailing at tam.si> wrote:
> I have type="mapserver" and the path to the mapfile within the file.
> Is tiled=true available only for type="wms"? I have output already set
> as WMS in the mapfile, can I use it somehow?
> Thanks,
> Matej
> 2012/10/4 Jim Klassen <klassen.js at gmail.com>:
>> You're likely something wrong. Do you have tiled=true set in the mapbook?
>> On Oct 3, 2012, at 3:54 PM, Matej Mailing wrote:
>>> Hi,
>>> I would also be interested in this solution. Currently it seems
>>> tilecache doesn't work - when moving map the surrounding views are
>>> "not loaded". Is this normal behaviour or am I doing something wrong?
>>> Thanks,
>>> Matej
>>> 2012/9/24 Mark Volz <MarkVolz at co.lyon.mn.us>:
>>>> Hello,
>>>> GeoMOOSE appears to request a larger image than what was displayed on the map. This allows for a user to pan around slightly before a new image would need to be requested from the server. It also makes tilled images appear much faster - since the tiles would start to load before a user could pan to the area. Is there any way to configure 2.6 so that we can request larger images so that GM 2.6 behaves more like 2.2?
>>>> Thanks
>>>> Mark Volz
>>>> GIS Specialist
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
