[Geomoose-users] metadata layer parameter
Jim Klassen
klassen.js at gmail.com
Tue Oct 9 06:57:29 PDT 2012
Just to confirm:
On my main 2.6 install, the metadata icon shows for all layers but makes a popup that says the metadata cannot be displayed for the layers where it is not defined.
I would think greying out or hiding the metadata icon if it isn't available would be good. I am a little worried this will create a special case for this tool. To avoid that, I am thinking whatever logic is used to determine if the metadata icon is visible should be done in the metadata layercontrol class.
Jim
On Oct 7, 2012, at 2:31 PM, Brian Fischer wrote:
> Sorry forgot to tell which parameter I was referencing.
> <param name="layer_controls.metadata.on">true</param>
> Brian Fischer, CFM
> Principal | GIS Project Manager
> Houston Engineering, Inc.
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brian Fischer
> Sent: Sunday, October 07, 2012 2:30 PM
> To: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] metadata layer parameter
> One more thing to add. It looks like if you change this config parameter to true then it adds the metadata icon to all layers and the new one I tried to add to a new layer works.
> This doesn’t seem like the behavior I would expect and isn’t the way it worked in previous GeoMoose versions. I would prefer to be able to define a metadata parameter per layer in the catalog and not have the icon show up for the others. I’m also not sure why the icon works only for the parcel layer.
> Thoughts on this functionality?
> Brian Fischer, CFM
> Sent: Sunday, October 07, 2012 2:20 PM
> Subject: [Geomoose-users] metadata layer parameter
> Has anyone else got the metadata parameter to work on any layer other than the parcels in the demo?
> It almost seems like it is hardcoded into that layer. If I comment it out in the mapbook it doesn’t remove it. If I tried to add a metadata parameter to another layer it doesn’t show up. Just wondering if this is a bug or my configuration.
> Brian Fischer, CFM
> <image001.jpg>
> 6901 E Fish Lake Rd. , Suite 140 • Maple Grove, MN• 55369
> www.houstoneng.com
> This entire message (including all forwards and replies) and any attachments are for the sole use of the intended recipient(s) and may contain proprietary, confidential, trade secret, work-product, attorney-client or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited and may be a violation of law. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121009/0c68908f/attachment.html>
More information about the Geomoose-users
