[Geomoose-users] How to set Google Setellite layer to display by default?
Brian Fischer
bfischer at houstoneng.com
Tue Oct 9 12:51:50 PDT 2012
The status for layer visibility has moved to the map-source element. So I can confirm that. Haven't played around with this too much for background layers and for layers that multiple=true is set.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Ed Boesenberg
Sent: Tuesday, October 09, 2012 1:35 PM
To: 'Bistrais, Bob'; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] How to set Google Setellite layer to display by default?
I tried both suggestions and neither worked.
From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]<mailto:[mailto:Bob.Bistrais at maine.gov]>
Sent: Tuesday, October 09, 2012 2:20 PM
To: Ed Boesenberg; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: RE: [Geomoose-users] How to set Google Setellite layer to display by default?
Hey- here's something else to check- (sorry- forgot to include the group on my first reply)-
In the map-sources section of the mapbook.xml:
<map-source name="google_satellite" type="google" google-type="satellite">
<layer name="all"/> <- add status="on" inside this tag
</map-source>
<map-source name="blank" type="wms" tiled="false">
<url>./images/blank.gif</url>
<layer name="blank" status="on"/> <- remove the status="on" from this tag
</map-source>
From: Ed Boesenberg [mailto:eboesenberg at niraengineers.com]
Sent: Tuesday, October 09, 2012 2:16 PM
To: Bistrais, Bob
At first I had the "None" layer's status set to "off" but that did nothing, so I removed it from the catalog and it still had no effect.
Sent: Tuesday, October 09, 2012 2:09 PM
To: Ed Boesenberg
Hi Ed,
Have you also checked that the "None" option, which is on by default, is now set to "off"? Just a thought.
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Ed Boesenberg
Sent: Tuesday, October 09, 2012 1:50 PM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] How to set Google Setellite layer to display by default?
How do I set the Google Satellite image layer to display by default? It is alwys turned off I have tried using status="on" in the layer catalog, see below. I am using GeoMoose 2.6.
<group title="Backgrounds" expand="true" multiple="false">
<layer title="Google Streets" src="google_streets/all" status="off" legend="false" fade="false" unfade="false"/>
<layer title="Google Satellite" src="google_satellite/all" status="on" legend="false" fade="false" unfade="false"/>
</group>
Thanks,
Ed
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121009/28c4a462/attachment.html>
More information about the Geomoose-users
