[Geomoose-users] How to set Google Setellite layer to display by default?
Anderson, Dean
anderson.dean at co.polk.or.us
Tue Oct 9 12:53:17 PDT 2012
I played around with this and it appears we have a bug. To test...
1. Remove status="off" from all lines in the catolog for "Backgrounds"
group.
2. In Mapgroup section removed status="off" from blank mapgroup as follows:
<map-source name="blank" type="wms" tiled="false">
<url>./images/blank.gif</url>
<layer name="blank" />
</map-source>
3. Added status on to LMIC Layer, OR YAHOO LAYERS or MAPQUEST layers and it
worked great. Like....
<map-source name="mapquest" type="xyz">
<layer name="osm" status="on" />
<url>http://otile1.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png</url>
<url>http://otile2.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png</url>
<url>http://otile3.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png</url>
<url>http://otile4.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png</url>
</map-source>
OR Like...
<map-source name="yahoo_satellite" type="yahoo" yahoo-type="satellite">
<layer name="all" status="on"/>
</map-source>
These work!
4. Did the same for GOOGLE layers and it did not work. So it looked like:
<map-source name="google_hybrid" type="google" google-type="hybrid">
</map-source>
NOW IT DOES NOT WORK. So it appears this may be a bug??
So my suggestion for now is set your default for yahoo or mapquest.
Dean R Anderson
IT Director
Polk County
On Tue, Oct 9, 2012 at 11:34 AM, Ed Boesenberg <
eboesenberg at niraengineers.com> wrote:
> I tried both suggestions and neither worked.****
> *From:* Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
> *Sent:* Tuesday, October 09, 2012 2:20 PM
> *To:* Ed Boesenberg; geomoose-users at lists.osgeo.org
> *Subject:* RE: [Geomoose-users] How to set Google Setellite layer to
> display by default?****
> Hey- here’s something else to check- (sorry- forgot to include the group
> on my first reply)-****
> In the map-sources section of the mapbook.xml:****
> <map-source name="google_satellite" type="google"
> google-type="satellite">****
> <layer name="all"/> <- add status=”on”
> inside this tag****
> </map-source>****
> <map-source name="blank" type="wms" tiled="false">****
> <url>./images/blank.gif</url>****
> <layer name="blank"
> status="on"/> <- remove the status=”on” from this tag
> </map-source>****
> *From:* Ed Boesenberg [mailto:eboesenberg at niraengineers.com<eboesenberg at niraengineers.com>]
> *Sent:* Tuesday, October 09, 2012 2:16 PM
> *To:* Bistrais, Bob
> At first I had the "None" layer's status set to "off" but that did
> nothing, so I removed it from the catalog and it still had no effect.****
> *Sent:* Tuesday, October 09, 2012 2:09 PM
> *To:* Ed Boesenberg
> Hi Ed,****
> Have you also checked that the “None” option, which is on by default, is
> now set to “off”? Just a thought.****
> *From:* geomoose-users-bounces at lists.osgeo.org [
> mailto:geomoose-users-bounces at lists.osgeo.org<geomoose-users-bounces at lists.osgeo.org>]
> *On Behalf Of *Ed Boesenberg
> *Sent:* Tuesday, October 09, 2012 1:50 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] How to set Google Setellite layer to display
> by default?****
> How do I set the Google Satellite image layer to display by default? It
> is alwys turned off I have tried using status="on" in the layer catalog,
> see below. I am using GeoMoose 2.6.****
> <group title="Backgrounds" expand="true" multiple="false">****
> <layer title="Google Streets" src="google_streets/all"
> status="off" legend="false" fade="false" unfade="false"/>****
> <layer title="Google Satellite" src="google_satellite/all"
> status="on" legend="false" fade="false" unfade="false"/>****
> </group>****
> Thanks,****
> Ed ****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121009/e203fcae/attachment-0001.html>
More information about the Geomoose-users
