[Geomoose-users] How to set Google Setellite layer to display by default?
Ed Boesenberg
eboesenberg at niraengineers.com
Tue Oct 9 13:44:34 PDT 2012
Thanks for checking on this. I will set Yahoo as my default background and
I will file a bug report.
From: Anderson, Dean [mailto:anderson.dean at co.polk.or.us]
Sent: Tuesday, October 09, 2012 3:53 PM
To: Ed Boesenberg
Cc: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] How to set Google Setellite layer to display
by default?
I played around with this and it appears we have a bug. To test...
1. Remove status="off" from all lines in the catolog for "Backgrounds"
group.
2. In Mapgroup section removed status="off" from blank mapgroup as follows:
<map-source name="blank" type="wms" tiled="false">
<url>./images/blank.gif</url>
<layer name="blank" />
</map-source>
3. Added status on to LMIC Layer, OR YAHOO LAYERS or MAPQUEST layers and it
worked great. Like....
<map-source name="mapquest" type="xyz">
<layer name="osm" status="on" />
<url>http://otile1.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png
<http://otile1.mqcdn.com/tiles/1.0.0/osm/$%7bz%7d/$%7bx%7d/$%7by%7d.png>
</url>
<url>http://otile2.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png
<http://otile2.mqcdn.com/tiles/1.0.0/osm/$%7bz%7d/$%7bx%7d/$%7by%7d.png>
</url>
<url>http://otile3.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png
<http://otile3.mqcdn.com/tiles/1.0.0/osm/$%7bz%7d/$%7bx%7d/$%7by%7d.png>
</url>
<url>http://otile4.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.png
<http://otile4.mqcdn.com/tiles/1.0.0/osm/$%7bz%7d/$%7bx%7d/$%7by%7d.png>
</url>
</map-source>
OR Like...
<map-source name="yahoo_satellite" type="yahoo" yahoo-type="satellite">
<layer name="all" status="on"/>
</map-source>
These work!
4. Did the same for GOOGLE layers and it did not work. So it looked like:
<map-source name="google_hybrid" type="google" google-type="hybrid">
</map-source>
NOW IT DOES NOT WORK. So it appears this may be a bug??
So my suggestion for now is set your default for yahoo or mapquest.
Dean R Anderson
IT Director
Polk County
On Tue, Oct 9, 2012 at 11:34 AM, Ed Boesenberg
<eboesenberg at niraengineers.com> wrote:
I tried both suggestions and neither worked.
From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
Sent: Tuesday, October 09, 2012 2:20 PM
To: Ed Boesenberg; geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] How to set Google Setellite layer to display
by default?
Hey- here's something else to check- (sorry- forgot to include the group on
my first reply)-
In the map-sources section of the mapbook.xml:
<map-source name="google_satellite" type="google"
google-type="satellite">
<layer name="all"/> <- add status="on"
inside this tag
</map-source>
<layer name="blank" status="on"/>
<- remove the status="on" from this tag
</map-source>
From: Ed Boesenberg [mailto:eboesenberg at niraengineers.com]
Sent: Tuesday, October 09, 2012 2:16 PM
To: Bistrais, Bob
by default?
At first I had the "None" layer's status set to "off" but that did nothing,
so I removed it from the catalog and it still had no effect.
Sent: Tuesday, October 09, 2012 2:09 PM
To: Ed Boesenberg
by default?
Hi Ed,
Have you also checked that the "None" option, which is on by default, is now
set to "off"? Just a thought.
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Ed Boesenberg
Sent: Tuesday, October 09, 2012 1:50 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] How to set Google Setellite layer to display by
default?
How do I set the Google Satellite image layer to display by default? It is
alwys turned off I have tried using status="on" in the layer catalog, see
below. I am using GeoMoose 2.6.
<group title="Backgrounds" expand="true" multiple="false">
<layer title="Google Streets" src="google_streets/all"
status="off" legend="false" fade="false" unfade="false"/>
<layer title="Google Satellite" src="google_satellite/all"
status="on" legend="false" fade="false" unfade="false"/>
</group>
Thanks,
Ed
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121009/69579fe2/attachment.html>
More information about the Geomoose-users
