[Geomoose-users] Opacity in Geomoose 2.6
Matej Mailing
mailing at tam.si
Mon Oct 15 04:00:57 PDT 2012
is the situation with the opacity attribute for mapsource different
than it was in July?
I have the same problem as described below.
Thanks,
Matej
2012/7/20 Dan Little <danlittle at yahoo.com>:
> Hi Scott,
> I just went through the 2.6 code and it looks like that got missed in
> testing. We'll need to add it back in. The entire API is there and the
> code but just not the parser to recognize the option.
> Any chance you'd be willing to write a quick ticket in our Trac? (
> http://trac.osgeo.org/geomoose/ )
> Thanks!
> ________________________________
> From: Scott Wolfert <swolfert at houstoneng.com>
> To: "'geomoose-users at lists.osgeo.org'" <geomoose-users at lists.osgeo.org>
> Sent: Friday, July 20, 2012 8:37 AM
> Subject: [Geomoose-users] Opacity in Geomoose 2.6
> Hello,
> I am wondering if anything has changed within the mapbook for opacity
> settings in Geomoose 2.6? I currently have it setup to be something like the
> following, however it is not working properly.
> <map-source name="Divisions" type="mapserver" opacity="0.5">
> <file>./data/Divisions.map</file>
> <layer name="Divisions" status="on" />
> </map-source>
> Has anyone had any luck with this in 2.6?
> Thanks for your help.
> Scott
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
