[Geomoose-users] Opacity in Geomoose 2.6
Brian Fischer
bfischer at houstoneng.com
Mon Oct 15 09:07:26 PDT 2012
This was fixed but is only in trunk SVN right now. http://trac.osgeo.org/geomoose/ticket/127
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
Sent: Monday, October 15, 2012 6:01 AM
To: Dan Little
Cc: Scott Wolfert; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Opacity in Geomoose 2.6
is the situation with the opacity attribute for mapsource different than it was in July?
I have the same problem as described below.
Thanks,
Matej
2012/7/20 Dan Little <danlittle at yahoo.com>:
> Hi Scott,
> I just went through the 2.6 code and it looks like that got missed in
> testing. We'll need to add it back in. The entire API is there and
> the code but just not the parser to recognize the option.
> Any chance you'd be willing to write a quick ticket in our Trac? (
> http://trac.osgeo.org/geomoose/ )
> Thanks!
> ________________________________
> From: Scott Wolfert <swolfert at houstoneng.com>
> To: "'geomoose-users at lists.osgeo.org'"
> <geomoose-users at lists.osgeo.org>
> Sent: Friday, July 20, 2012 8:37 AM
> Subject: [Geomoose-users] Opacity in Geomoose 2.6
> Hello,
> I am wondering if anything has changed within the mapbook for opacity
> settings in Geomoose 2.6? I currently have it setup to be something
> like the following, however it is not working properly.
> <map-source name="Divisions" type="mapserver" opacity="0.5">
> <file>./data/Divisions.map</file>
> <layer name="Divisions" status="on" />
> </map-source>
> Has anyone had any luck with this in 2.6?
> Thanks for your help.
> Scott
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
