[Geomoose-users] Opacity in Geomoose 2.6
Eli Adam
eadam at co.lincoln.or.us
Mon Oct 15 11:22:56 PDT 2012
On Mon, Oct 15, 2012 at 10:12 AM, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> I have overwritten geomoose directory (containing js files) and php
> directory on my test server and it doesn't work.
> Which files do I have to get from the trunk - where is the parser
> located? I know it's always the best to use the complete package
> especially if there are major version differences.
Here is the changeset referenced from the ticket,
http://trac.osgeo.org/geomoose/changeset/878 including the rebuilt
javascript.
There are also nightly builds and downloads,
http://www.geomoose.org/info/download.html
HTH, Eli
> Thanks,
> Matej
> 2012/10/15 Brian Fischer <bfischer at houstoneng.com>:
>> This was fixed but is only in trunk SVN right now. http://trac.osgeo.org/geomoose/ticket/127
>> Brian Fischer, CFM
>> Principal | GIS Project Manager
>> Houston Engineering, Inc.
>> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
>> -----Original Message-----
>> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
>> Sent: Monday, October 15, 2012 6:01 AM
>> To: Dan Little
>> Cc: Scott Wolfert; geomoose-users at lists.osgeo.org
>> Subject: Re: [Geomoose-users] Opacity in Geomoose 2.6
>> Hi,
>> is the situation with the opacity attribute for mapsource different than it was in July?
>> I have the same problem as described below.
>> Thanks,
>> Matej
>> 2012/7/20 Dan Little <danlittle at yahoo.com>:
>>> Hi Scott,
>>> I just went through the 2.6 code and it looks like that got missed in
>>> testing. We'll need to add it back in. The entire API is there and
>>> the code but just not the parser to recognize the option.
>>> Any chance you'd be willing to write a quick ticket in our Trac? (
>>> http://trac.osgeo.org/geomoose/ )
>>> Thanks!
>>> ________________________________
>>> From: Scott Wolfert <swolfert at houstoneng.com>
>>> To: "'geomoose-users at lists.osgeo.org'"
>>> <geomoose-users at lists.osgeo.org>
>>> Sent: Friday, July 20, 2012 8:37 AM
>>> Subject: [Geomoose-users] Opacity in Geomoose 2.6
>>> Hello,
>>> I am wondering if anything has changed within the mapbook for opacity
>>> settings in Geomoose 2.6? I currently have it setup to be something
>>> like the following, however it is not working properly.
>>> <map-source name="Divisions" type="mapserver" opacity="0.5">
>>> <file>./data/Divisions.map</file>
>>> <layer name="Divisions" status="on" />
>>> </map-source>
>>> Has anyone had any luck with this in 2.6?
>>> Thanks for your help.
>>> Scott
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
