[Geomoose-users] Opacity in Geomoose 2.6
Matej Mailing
mailing at tam.si
Mon Oct 15 11:50:08 PDT 2012
Excellent, it's working.
Thanks a lot!
Regards,
Matej
2012/10/15 Eli Adam <eadam at co.lincoln.or.us>:
> On Mon, Oct 15, 2012 at 10:12 AM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> I have overwritten geomoose directory (containing js files) and php
>> directory on my test server and it doesn't work.
>> Which files do I have to get from the trunk - where is the parser
>> located? I know it's always the best to use the complete package
>> especially if there are major version differences.
> Here is the changeset referenced from the ticket,
> http://trac.osgeo.org/geomoose/changeset/878 including the rebuilt
> javascript.
> There are also nightly builds and downloads,
> http://www.geomoose.org/info/download.html
> HTH, Eli
>> Thanks,
>> Matej
>> 2012/10/15 Brian Fischer <bfischer at houstoneng.com>:
>>> This was fixed but is only in trunk SVN right now. http://trac.osgeo.org/geomoose/ticket/127
>>> Brian Fischer, CFM
>>> Principal | GIS Project Manager
>>> Houston Engineering, Inc.
>>> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
>>> -----Original Message-----
>>> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
>>> Sent: Monday, October 15, 2012 6:01 AM
>>> To: Dan Little
>>> Cc: Scott Wolfert; geomoose-users at lists.osgeo.org
>>> Subject: Re: [Geomoose-users] Opacity in Geomoose 2.6
>>> Hi,
>>> is the situation with the opacity attribute for mapsource different than it was in July?
>>> I have the same problem as described below.
>>> Thanks,
>>> Matej
>>> 2012/7/20 Dan Little <danlittle at yahoo.com>:
>>>> Hi Scott,
>>>> I just went through the 2.6 code and it looks like that got missed in
>>>> testing. We'll need to add it back in. The entire API is there and
>>>> the code but just not the parser to recognize the option.
>>>> Any chance you'd be willing to write a quick ticket in our Trac? (
>>>> http://trac.osgeo.org/geomoose/ )
>>>> Thanks!
>>>> ________________________________
>>>> From: Scott Wolfert <swolfert at houstoneng.com>
>>>> To: "'geomoose-users at lists.osgeo.org'"
>>>> <geomoose-users at lists.osgeo.org>
>>>> Sent: Friday, July 20, 2012 8:37 AM
>>>> Subject: [Geomoose-users] Opacity in Geomoose 2.6
>>>> Hello,
>>>> I am wondering if anything has changed within the mapbook for opacity
>>>> settings in Geomoose 2.6? I currently have it setup to be something
>>>> like the following, however it is not working properly.
>>>> <map-source name="Divisions" type="mapserver" opacity="0.5">
>>>> <file>./data/Divisions.map</file>
>>>> <layer name="Divisions" status="on" />
>>>> </map-source>
>>>> Has anyone had any luck with this in 2.6?
>>>> Thanks for your help.
>>>> Scott
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
