[Geomoose-users] Fwd: UTF-8 encoding in sent data to the	services
    Eli Adam
    eadam at co.lincoln.or.us
    Tue Oct 16 07:23:27 PDT 2012
Solutions are always helpful, it helps inform other users and helps
anyone searching the mail archives.
Thanks, Eli
On Tue, Oct 16, 2012 at 2:29 AM, Matej Mailing <mailing at tam.si> wrote:
> Found it out - I simply replace those values with their corresponding
> letters in service's php file with str_replace and it works.
> It looks like I post too quick, but perhaps someone will benefit from
> such "monologues with solutions" :-)
> Regards,
> Matej
> ---------- Forwarded message ----------
> From: Matej Mailing <mailing at tam.si>
> Date: 2012/10/16
> Subject: UTF-8 encoding in sent data to the services
> To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> Hi,
> I have found out some problems when entering special chars (ü, ä
> etc.). The page encoding is set to UTF-8, but I can see in Firebug
> that the data sent to the service as value0 for the input "ü" is seen
> as: "%FC".
> I am not sure if this should be set in dojo or somewhere else? We need
> to get UTF-8 native symbols into the php of services so we can use
> them in queries etc.
> Thanks for any ideas and suggestions, I am pretty lost here with this.
> Regards,
> Matej
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
