[Geomoose-users] Fwd: UTF-8 encoding in sent data to the	services
    Jim Klassen
    klassen.js at gmail.com
    Tue Oct 16 08:00:39 PDT 2012
Does this have anything to do with the geomoose.html encoding set to ISO-8859-1 instead of UTF-8?
(It has always bugged me that it was set to Latin-1, but I've been told it would cause chaos for US Windows deployments to set it to UTF-8.)
On Oct 16, 2012, at 9:23 AM, Eli Adam wrote:
> Solutions are always helpful, it helps inform other users and helps
> anyone searching the mail archives.
> Thanks, Eli
> On Tue, Oct 16, 2012 at 2:29 AM, Matej Mailing <mailing at tam.si> wrote:
>> Found it out - I simply replace those values with their corresponding
>> letters in service's php file with str_replace and it works.
>> It looks like I post too quick, but perhaps someone will benefit from
>> such "monologues with solutions" :-)
>> Regards,
>> Matej
>> ---------- Forwarded message ----------
>> From: Matej Mailing <mailing at tam.si>
>> Date: 2012/10/16
>> Subject: UTF-8 encoding in sent data to the services
>> To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>> Hi,
>> I have found out some problems when entering special chars (ü, ä
>> etc.). The page encoding is set to UTF-8, but I can see in Firebug
>> that the data sent to the service as value0 for the input "ü" is seen
>> as: "%FC".
>> I am not sure if this should be set in dojo or somewhere else? We need
>> to get UTF-8 native symbols into the php of services so we can use
>> them in queries etc.
>> Thanks for any ideas and suggestions, I am pretty lost here with this.
>> Regards,
>> Matej
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
