[Geomoose-users] Fwd: UTF-8 encoding in sent data to the	services
    Matej Mailing
    mailing at tam.si
    Tue Oct 16 08:11:01 PDT 2012
Jim, I think this is not on the Mapserver "layer" yet. It's a simple
ajax data submit to the PHP and the data is then replaced in PHP
before being sent to Mapserver..
Regards,
Matej
2012/10/16 Jim Klassen <klassen.js at gmail.com>:
> Does this have anything to do with the geomoose.html encoding set to ISO-8859-1 instead of UTF-8?
> (It has always bugged me that it was set to Latin-1, but I've been told it would cause chaos for US Windows deployments to set it to UTF-8.)
> On Oct 16, 2012, at 9:23 AM, Eli Adam wrote:
>> Solutions are always helpful, it helps inform other users and helps
>> anyone searching the mail archives.
>> Thanks, Eli
>> On Tue, Oct 16, 2012 at 2:29 AM, Matej Mailing <mailing at tam.si> wrote:
>>> Found it out - I simply replace those values with their corresponding
>>> letters in service's php file with str_replace and it works.
>>> It looks like I post too quick, but perhaps someone will benefit from
>>> such "monologues with solutions" :-)
>>> Regards,
>>> Matej
>>> ---------- Forwarded message ----------
>>> From: Matej Mailing <mailing at tam.si>
>>> Date: 2012/10/16
>>> Subject: UTF-8 encoding in sent data to the services
>>> To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>>> Hi,
>>> I have found out some problems when entering special chars (ü, ä
>>> etc.). The page encoding is set to UTF-8, but I can see in Firebug
>>> that the data sent to the service as value0 for the input "ü" is seen
>>> as: "%FC".
>>> I am not sure if this should be set in dojo or somewhere else? We need
>>> to get UTF-8 native symbols into the php of services so we can use
>>> them in queries etc.
>>> Thanks for any ideas and suggestions, I am pretty lost here with this.
>>> Regards,
>>> Matej
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
