[Geomoose-users] Fwd: UTF-8 encoding in sent data to the services
Jim Klassen
klassen.js at gmail.com
Tue Oct 16 08:23:34 PDT 2012
I didn't say anything about MapServer. I'm asking about the encoding the browser is operating in (set by the charset line in geomoose.html).
Replacing specific letters seems like trouble to me, knowing what charsets are running where and calling something like iconv to convert between them seems more robust to me.
On Oct 16, 2012, at 10:11 AM, Matej Mailing wrote:
> Jim, I think this is not on the Mapserver "layer" yet. It's a simple
> ajax data submit to the PHP and the data is then replaced in PHP
> before being sent to Mapserver..
> Regards,
> Matej
> 2012/10/16 Jim Klassen <klassen.js at gmail.com>:
>> Does this have anything to do with the geomoose.html encoding set to ISO-8859-1 instead of UTF-8?
>> (It has always bugged me that it was set to Latin-1, but I've been told it would cause chaos for US Windows deployments to set it to UTF-8.)
>> On Oct 16, 2012, at 9:23 AM, Eli Adam wrote:
>>> Solutions are always helpful, it helps inform other users and helps
>>> anyone searching the mail archives.
>>> Thanks, Eli
>>> On Tue, Oct 16, 2012 at 2:29 AM, Matej Mailing <mailing at tam.si> wrote:
>>>> Found it out - I simply replace those values with their corresponding
>>>> letters in service's php file with str_replace and it works.
>>>> It looks like I post too quick, but perhaps someone will benefit from
>>>> such "monologues with solutions" :-)
>>>> Regards,
>>>> Matej
>>>> ---------- Forwarded message ----------
>>>> From: Matej Mailing <mailing at tam.si>
>>>> Date: 2012/10/16
>>>> Subject: UTF-8 encoding in sent data to the services
>>>> To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>>>> Hi,
>>>> I have found out some problems when entering special chars (ü, ä
>>>> etc.). The page encoding is set to UTF-8, but I can see in Firebug
>>>> that the data sent to the service as value0 for the input "ü" is seen
>>>> as: "%FC".
>>>> I am not sure if this should be set in dojo or somewhere else? We need
>>>> to get UTF-8 native symbols into the php of services so we can use
>>>> them in queries etc.
>>>> Thanks for any ideas and suggestions, I am pretty lost here with this.
>>>> Regards,
>>>> Matej
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
