[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
Efstathios Arapostathis e.arapostathis at gmail.com
Tue Oct 16 10:45:24 PDT 2012
   I've installed the new version of Geomoose 2.6 (I was using version 2.2)
but I'm facing problems with the identify service.
I've changed my map file (like the firestations.map file which I used as a
template).
At first I saw that now we have to use a template object in our map script?
The error message I'm receing is this:
*The service you called did not return valid XML.* If you are the system
administrator, you should look into this, if you are not the system
administrator you should tell them about this.
Below I paste three files. First one is my map file. Second one is my
identify.html file that I was using on Geomoose 2.2. The third one is the
imagemap_record file which I tried to use as a template.
*MAP FILE*
MAP
    NAME 'ekthemanew'
    SIZE 800 650
    STATUS ON
    EXTENT  2120556.1495784903 3610867.081920644 3593336.723825039
5120032.47940209
    UNITS METERS
    INCLUDE "../../geomoose_globals.map"
    TRANSPARENT TRUE
    IMAGETYPE PNG
    QUERYMAP
        STATUS ON
        STYLE SELECTED
    END
    PROJECTION
        "init=epsg:3857"
    END
    WEB
        QUERYFORMAT "text/html"
        INCLUDE "../../temp_directory.map"
        METADATA
            "wms_title" "WMS Ekthemanew"
            "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe"
            "wms_srs" "EPSG:3857"
            'ows_enable_request' '*'
        END
    END
    LEGEND
          STATUS ON
          LABEL
        TYPE TRUETYPE
        FONT vera_sans
        SIZE 8
        COLOR 0 0 0
          END
    END
    DEBUG ON
    LAYER
        DUMP TRUE
        NAME 'ekthemanew'
        CONNECTIONTYPE postgis
        CONNECTION 'host=localhost user=postgres password=1234
dbname=nath_museum'
           DATA 'the_geom FROM ekthemanew'
        TYPE POINT
        STATUS ON
        CLASS
            NAME 'ekthemanew'
              STYLE
             SYMBOL 'arxaia'
             SIZE 15
            END
          END
        #MAXSCALE 1500000
        HEADER 'imagemap_header.xml'
        TEMPLATE 'identify_ekthemanew.html'
        FOOTER 'imagemap_footer.xml'
        METADATA
            'identify_record' 'identify_ekthemanew.html'
            "ows_title" "Ekthemanew"
            "gml_include_items" "all"
            "ows_include_items" "all"
            "gml_exclude_items" "SHAPE_area,SHAPE_len"
        END
        TOLERANCEUNITS FEET
        TOLERANCE 1000000
    END
END ## end Map
*IDENTIFY_EKTHEMANEW.HTML FILE*
<!-- MapServer Template -->
<tr>
<td colspan="2"><b>Έκθεμα:</b></td>
</tr>
<tr>
<td align="right">Συλλογή:</td>
<td>[syllogh_ek]</td>
</tr>
<tr>
<td align="right">Περίοδος:</td>
<td>[xronol_ek]</td>
</tr>
<tr>
<td align="right">Περιγραφή:</td>
<td>[desc_ek]</td>
</tr>
*IMAGEMAP_RECORD.XML*
<popup shape='circle' coords='[shpxy xf="," proj=image],5'>
    <title>Ekthemata</title>
    <id>Id-[gid]</id>
    <item title="Nane:">[name_ek]</item>
    <item title="Collection:">[syllogh_ek]</item>
</popup>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121016/664ee6d1/attachment-0001.html>
More information about the Geomoose-users mailing list
