[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
Efstathios Arapostathis
e.arapostathis at gmail.com
Tue Oct 16 10:47:15 PDT 2012
I've installed the new version of Geomoose 2.6 (I was using version 2.2)
but I'm facing problems with the identify service.
I've changed my map file (like the firestations.map file which I used as a
template).
At first I saw that now we have to use a template object in our map script?
The error message I'm receing is this:
*The service you called did not return valid XML.* If you are the system
administrator, you should look into this, if you are not the system
administrator you should tell them about this.
Below I paste three files. First one is my map file. Second one is my
identify.html file that I was using on Geomoose 2.2. The third one is the
imagemap_record file which I tried to use as a template.
*MAP FILE*
MAP
NAME 'ekthemanew'
SIZE 800 650
STATUS ON
EXTENT 2120556.1495784903 3610867.081920644 3593336.723825039
5120032.47940209
UNITS METERS
INCLUDE "../../geomoose_globals.map"
TRANSPARENT TRUE
IMAGETYPE PNG
QUERYMAP
STATUS ON
STYLE SELECTED
END
PROJECTION
"init=epsg:3857"
END
WEB
QUERYFORMAT "text/html"
INCLUDE "../../temp_directory.map"
METADATA
"wms_title" "WMS Ekthemanew"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe"
"wms_srs" "EPSG:3857"
'ows_enable_request' '*'
END
END
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT vera_sans
SIZE 8
COLOR 0 0 0
END
END
DEBUG ON
LAYER
DUMP TRUE
NAME 'ekthemanew'
CONNECTIONTYPE postgis
CONNECTION 'host=localhost user=postgres password=1234
dbname=nath_museum'
DATA 'the_geom FROM ekthemanew'
TYPE POINT
STATUS ON
CLASS
NAME 'ekthemanew'
STYLE
SYMBOL 'arxaia'
SIZE 15
END
END
#MAXSCALE 1500000
HEADER 'imagemap_header.xml'
TEMPLATE 'identify_ekthemanew.html'
FOOTER 'imagemap_footer.xml'
METADATA
'identify_record' 'identify_ekthemanew.html'
"ows_title" "Ekthemanew"
"gml_include_items" "all"
"ows_include_items" "all"
"gml_exclude_items" "SHAPE_area,SHAPE_len"
END
TOLERANCEUNITS FEET
TOLERANCE 1000000
END
END ## end Map
*IDENTIFY_EKTHEMANEW.HTML FILE*
<!-- MapServer Template -->
<tr>
<td colspan="2"><b>Έκθεμα:</b></td>
</tr>
<tr>
<td align="right">Συλλογή:</td>
<td>[syllogh_ek]</td>
</tr>
<tr>
<td align="right">Περίοδος:</td>
<td>[xronol_ek]</td>
</tr>
<tr>
<td align="right">Περιγραφή:</td>
<td>[desc_ek]</td>
</tr>
*IMAGEMAP_RECORD.XML*
<popup shape='circle' coords='[shpxy xf="," proj=image],5'>
<title>Ekthemata</title>
<id>Id-[gid]</id>
<item title="Nane:">[name_ek]</item>
<item title="Collection:">[syllogh_ek]</item>
</popup>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121016/0483e73c/attachment.html>
More information about the Geomoose-users
