[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
Matej Mailing
mailing at tam.si
Tue Oct 16 11:10:42 PDT 2012
try to check to output of the template.php with Firebug and perhaps
turning the debugging mode on. You will get more information then.
Regards,
Matej
2012/10/16 Efstathios Arapostathis <e.arapostathis at gmail.com>:
> Hi,
> I've installed the new version of Geomoose 2.6 (I was using version 2.2)
> but I'm facing problems with the identify service.
> I've changed my map file (like the firestations.map file which I used as a
> template).
> At first I saw that now we have to use a template object in our map script?
> The error message I'm receing is this:
> The service you called did not return valid XML. If you are the system
> administrator, you should look into this, if you are not the system
> administrator you should tell them about this.
> Below I paste three files. First one is my map file. Second one is my
> identify.html file that I was using on Geomoose 2.2. The third one is the
> imagemap_record file which I tried to use as a template.
> MAP FILE
> MAP
> NAME 'ekthemanew'
> SIZE 800 650
> STATUS ON
> EXTENT 2120556.1495784903 3610867.081920644 3593336.723825039
> 5120032.47940209
> UNITS METERS
> INCLUDE "../../geomoose_globals.map"
> TRANSPARENT TRUE
> IMAGETYPE PNG
> QUERYMAP
> STATUS ON
> STYLE SELECTED
> END
> PROJECTION
> "init=epsg:3857"
> END
> WEB
> QUERYFORMAT "text/html"
> INCLUDE "../../temp_directory.map"
> METADATA
> "wms_title" "WMS Ekthemanew"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe"
> "wms_srs" "EPSG:3857"
> 'ows_enable_request' '*'
> END
> END
> LEGEND
> STATUS ON
> LABEL
> TYPE TRUETYPE
> FONT vera_sans
> SIZE 8
> COLOR 0 0 0
> END
> END
> DEBUG ON
> LAYER
> DUMP TRUE
> NAME 'ekthemanew'
> CONNECTIONTYPE postgis
> CONNECTION 'host=localhost user=postgres password=1234
> dbname=nath_museum'
> DATA 'the_geom FROM ekthemanew'
> TYPE POINT
> STATUS ON
> CLASS
> NAME 'ekthemanew'
> STYLE
> SYMBOL 'arxaia'
> SIZE 15
> END
> END
> #MAXSCALE 1500000
> HEADER 'imagemap_header.xml'
> TEMPLATE 'identify_ekthemanew.html'
> FOOTER 'imagemap_footer.xml'
> METADATA
> 'identify_record' 'identify_ekthemanew.html'
> "ows_title" "Ekthemanew"
> "gml_include_items" "all"
> "ows_include_items" "all"
> "gml_exclude_items" "SHAPE_area,SHAPE_len"
> END
> TOLERANCEUNITS FEET
> TOLERANCE 1000000
> END
> END ## end Map
> IDENTIFY_EKTHEMANEW.HTML FILE
> <!-- MapServer Template -->
> <tr>
> <td colspan="2"><b>Έκθεμα:</b></td>
> </tr>
> <tr>
> <td align="right">Συλλογή:</td>
> <td>[syllogh_ek]</td>
> </tr>
> <tr>
> <td align="right">Περίοδος:</td>
> <td>[xronol_ek]</td>
> </tr>
> <tr>
> <td align="right">Περιγραφή:</td>
> <td>[desc_ek]</td>
> </tr>
> IMAGEMAP_RECORD.XML
> <popup shape='circle' coords='[shpxy xf="," proj=image],5'>
> <title>Ekthemata</title>
> <id>Id-[gid]</id>
> <item title="Nane:">[name_ek]</item>
> <item title="Collection:">[syllogh_ek]</item>
> </popup>
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
