[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
Efstathios Arapostathis
e.arapostathis at gmail.com
Wed Oct 17 01:42:02 PDT 2012
I've tried firebug, I'm receiving the following message:
Fatal error: Uncaught exception 'MapScriptException' with message
'Unable to construct shapeObj.' in
C:\ms4w\apps\geomoose2\htdocs\php\identify.php:145
Stack trace:
#0 C:\ms4w\apps\geomoose2\htdocs\php\identify.php(145): ms_shapeObjFromWkt('')
#1 {main}
thrown in C:\ms4w\apps\geomoose2\htdocs\php\identify.php on line 145
Additional Info: My layer is a PostGIS Layer. I'm attaching the map file
and the identify.html with some changes that I've done.
Any help would be really appreciated.
kind regards,
Stathis
On Tue, Oct 16, 2012 at 9:10 PM, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> try to check to output of the template.php with Firebug and perhaps
> turning the debugging mode on. You will get more information then.
> Regards,
> Matej
> 2012/10/16 Efstathios Arapostathis <e.arapostathis at gmail.com>:
> > Hi,
> > I've installed the new version of Geomoose 2.6 (I was using version
> 2.2)
> > but I'm facing problems with the identify service.
> > I've changed my map file (like the firestations.map file which I used as
> a
> > template).
> > At first I saw that now we have to use a template object in our map
> script?
> > The error message I'm receing is this:
> > The service you called did not return valid XML. If you are the system
> > administrator, you should look into this, if you are not the system
> > administrator you should tell them about this.
> > Below I paste three files. First one is my map file. Second one is my
> > identify.html file that I was using on Geomoose 2.2. The third one is the
> > imagemap_record file which I tried to use as a template.
> > MAP FILE
> > MAP
> > NAME 'ekthemanew'
> > SIZE 800 650
> > STATUS ON
> > EXTENT 2120556.1495784903 3610867.081920644 3593336.723825039
> > 5120032.47940209
> > UNITS METERS
> > INCLUDE "../../geomoose_globals.map"
> > TRANSPARENT TRUE
> > IMAGETYPE PNG
> > QUERYMAP
> > STATUS ON
> > STYLE SELECTED
> > END
> > PROJECTION
> > "init=epsg:3857"
> > END
> > WEB
> > QUERYFORMAT "text/html"
> > INCLUDE "../../temp_directory.map"
> > METADATA
> > "wms_title" "WMS Ekthemanew"
> > "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe"
> > "wms_srs" "EPSG:3857"
> > 'ows_enable_request' '*'
> > END
> > END
> > LEGEND
> > STATUS ON
> > LABEL
> > TYPE TRUETYPE
> > FONT vera_sans
> > SIZE 8
> > COLOR 0 0 0
> > END
> > END
> > DEBUG ON
> > LAYER
> > DUMP TRUE
> > NAME 'ekthemanew'
> > CONNECTIONTYPE postgis
> > CONNECTION 'host=localhost user=postgres password=1234
> > dbname=nath_museum'
> > DATA 'the_geom FROM ekthemanew'
> > TYPE POINT
> > STATUS ON
> > CLASS
> > NAME 'ekthemanew'
> > STYLE
> > SYMBOL 'arxaia'
> > SIZE 15
> > END
> > END
> > #MAXSCALE 1500000
> > HEADER 'imagemap_header.xml'
> > TEMPLATE 'identify_ekthemanew.html'
> > FOOTER 'imagemap_footer.xml'
> > METADATA
> > 'identify_record' 'identify_ekthemanew.html'
> > "ows_title" "Ekthemanew"
> > "gml_include_items" "all"
> > "ows_include_items" "all"
> > "gml_exclude_items" "SHAPE_area,SHAPE_len"
> > END
> > TOLERANCEUNITS FEET
> > TOLERANCE 1000000
> > END
> > END ## end Map
> > IDENTIFY_EKTHEMANEW.HTML FILE
> > <!-- MapServer Template -->
> > <tr>
> > <td colspan="2"><b>Έκθεμα:</b></td>
> > </tr>
> > <tr>
> > <td align="right">Συλλογή:</td>
> > <td>[syllogh_ek]</td>
> > </tr>
> > <tr>
> > <td align="right">Περίοδος:</td>
> > <td>[xronol_ek]</td>
> > </tr>
> > <tr>
> > <td align="right">Περιγραφή:</td>
> > <td>[desc_ek]</td>
> > </tr>
> > IMAGEMAP_RECORD.XML
> > <popup shape='circle' coords='[shpxy xf="," proj=image],5'>
> > <title>Ekthemata</title>
> > <id>Id-[gid]</id>
> > <item title="Nane:">[name_ek]</item>
> > <item title="Collection:">[syllogh_ek]</item>
> > </popup>
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/c7b11c80/attachment.html>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/c7b11c80/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/c7b11c80/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/c7b11c80/attachment-0001.obj>
More information about the Geomoose-users
