[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
Matej Mailing
mailing at tam.si
Wed Oct 17 03:10:32 PDT 2012
I am not so familiar with Mapscript yet, but it seems strange to me
that this "reprojectWKT($queryShape->toWkt(), $shape_proj, $map_proj)"
returns empty string. Try setting $DEBUG = true at the beginning of
the the identify.php, there could be some interesting debugging
information in the apache error log.
Regards,
Matej
2012/10/17 Efstathios Arapostathis <e.arapostathis at gmail.com>:
> Hi,
> I've tried firebug, I'm receiving the following message:
> Fatal error: Uncaught exception 'MapScriptException' with message 'Unable to
> construct shapeObj.' in C:\ms4w\apps\geomoose2\htdocs\php\identify.php:145
> Stack trace:
> #0 C:\ms4w\apps\geomoose2\htdocs\php\identify.php(145):
> ms_shapeObjFromWkt('')
> #1 {main}
> thrown in C:\ms4w\apps\geomoose2\htdocs\php\identify.php on line 145
> Additional Info: My layer is a PostGIS Layer. I'm attaching the map file and
> the identify.html with some changes that I've done.
> Any help would be really appreciated.
> kind regards,
> Stathis
> On Tue, Oct 16, 2012 at 9:10 PM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> try to check to output of the template.php with Firebug and perhaps
>> turning the debugging mode on. You will get more information then.
>> Regards,
>> Matej
>> 2012/10/16 Efstathios Arapostathis <e.arapostathis at gmail.com>:
>> > Hi,
>> > I've installed the new version of Geomoose 2.6 (I was using version
>> > 2.2)
>> > but I'm facing problems with the identify service.
>> > I've changed my map file (like the firestations.map file which I used as
>> > a
>> > template).
>> > At first I saw that now we have to use a template object in our map
>> > script?
>> > The error message I'm receing is this:
>> > The service you called did not return valid XML. If you are the system
>> > administrator, you should look into this, if you are not the system
>> > administrator you should tell them about this.
>> > Below I paste three files. First one is my map file. Second one is my
>> > identify.html file that I was using on Geomoose 2.2. The third one is
>> > the
>> > imagemap_record file which I tried to use as a template.
>> > MAP FILE
>> > MAP
>> > NAME 'ekthemanew'
>> > SIZE 800 650
>> > STATUS ON
>> > EXTENT 2120556.1495784903 3610867.081920644 3593336.723825039
>> > 5120032.47940209
>> > UNITS METERS
>> > INCLUDE "../../geomoose_globals.map"
>> > TRANSPARENT TRUE
>> > IMAGETYPE PNG
>> > QUERYMAP
>> > STATUS ON
>> > STYLE SELECTED
>> > END
>> > PROJECTION
>> > "init=epsg:3857"
>> > END
>> > WEB
>> > QUERYFORMAT "text/html"
>> > INCLUDE "../../temp_directory.map"
>> > METADATA
>> > "wms_title" "WMS Ekthemanew"
>> > "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe"
>> > "wms_srs" "EPSG:3857"
>> > 'ows_enable_request' '*'
>> > END
>> > END
>> > LEGEND
>> > STATUS ON
>> > LABEL
>> > TYPE TRUETYPE
>> > FONT vera_sans
>> > SIZE 8
>> > COLOR 0 0 0
>> > END
>> > END
>> > DEBUG ON
>> > LAYER
>> > DUMP TRUE
>> > NAME 'ekthemanew'
>> > CONNECTIONTYPE postgis
>> > CONNECTION 'host=localhost user=postgres password=1234
>> > dbname=nath_museum'
>> > DATA 'the_geom FROM ekthemanew'
>> > TYPE POINT
>> > STATUS ON
>> > CLASS
>> > NAME 'ekthemanew'
>> > STYLE
>> > SYMBOL 'arxaia'
>> > SIZE 15
>> > END
>> > END
>> > #MAXSCALE 1500000
>> > HEADER 'imagemap_header.xml'
>> > TEMPLATE 'identify_ekthemanew.html'
>> > FOOTER 'imagemap_footer.xml'
>> > METADATA
>> > 'identify_record' 'identify_ekthemanew.html'
>> > "ows_title" "Ekthemanew"
>> > "gml_include_items" "all"
>> > "ows_include_items" "all"
>> > "gml_exclude_items" "SHAPE_area,SHAPE_len"
>> > END
>> > TOLERANCEUNITS FEET
>> > TOLERANCE 1000000
>> > END
>> > END ## end Map
>> > IDENTIFY_EKTHEMANEW.HTML FILE
>> > <!-- MapServer Template -->
>> > <tr>
>> > <td colspan="2"><b>Έκθεμα:</b></td>
>> > </tr>
>> > <tr>
>> > <td align="right">Συλλογή:</td>
>> > <td>[syllogh_ek]</td>
>> > </tr>
>> > <tr>
>> > <td align="right">Περίοδος:</td>
>> > <td>[xronol_ek]</td>
>> > </tr>
>> > <tr>
>> > <td align="right">Περιγραφή:</td>
>> > <td>[desc_ek]</td>
>> > </tr>
>> > IMAGEMAP_RECORD.XML
>> > <popup shape='circle' coords='[shpxy xf="," proj=image],5'>
>> > <title>Ekthemata</title>
>> > <id>Id-[gid]</id>
>> > <item title="Nane:">[name_ek]</item>
>> > <item title="Collection:">[syllogh_ek]</item>
>> > </popup>
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
