[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
    Efstathios Arapostathis
    e.arapostathis at gmail.com
    Wed Oct 17 06:13:40 PDT 2012
Actually I believe that it just ignores the layer.
I'm getting the geocoordinates of the spot but I'm not getting any
attribute-info
So, I guess that identify service works in the same way *(by creating an
identify.html file and mentioning it in the map file in Layer's metadata
map object as:  'identify_record'    'identify.html')*
It might be something silly that I've forgotten.
Any idea is welcomed.
Many many thanks for the responses.
Stathis
On Wed, Oct 17, 2012 at 1:10 PM, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> I am not so familiar with Mapscript yet, but it seems strange to me
> that this "reprojectWKT($queryShape->toWkt(), $shape_proj, $map_proj)"
> returns empty string. Try setting $DEBUG = true at the beginning of
> the the identify.php, there could be some interesting debugging
> information in the apache error log.
> Regards,
> Matej
> 2012/10/17 Efstathios Arapostathis <e.arapostathis at gmail.com>:
> > Hi,
> >   I've tried firebug, I'm receiving the following message:
> > Fatal error: Uncaught exception 'MapScriptException' with message
> 'Unable to
> > construct shapeObj.' in
> C:\ms4w\apps\geomoose2\htdocs\php\identify.php:145
> > Stack trace:
> > #0 C:\ms4w\apps\geomoose2\htdocs\php\identify.php(145):
> > ms_shapeObjFromWkt('')
> > #1 {main}
> >   thrown in C:\ms4w\apps\geomoose2\htdocs\php\identify.php on line 145
> > Additional Info: My layer is a PostGIS Layer. I'm attaching the map file
> and
> > the identify.html with some changes that I've done.
> > Any help would be really appreciated.
> > kind regards,
> > Stathis
> > On Tue, Oct 16, 2012 at 9:10 PM, Matej Mailing <mailing at tam.si> wrote:
> >> Hi,
> >> try to check to output of the template.php with Firebug and perhaps
> >> turning the debugging mode on. You will get more information then.
> >> Regards,
> >> Matej
> >> 2012/10/16 Efstathios Arapostathis <e.arapostathis at gmail.com>:
> >> > Hi,
> >> >    I've installed the new version of Geomoose 2.6 (I was using version
> >> > 2.2)
> >> > but I'm facing problems with the identify service.
> >> > I've changed my map file (like the firestations.map file which I used
> as
> >> > a
> >> > template).
> >> > At first I saw that now we have to use a template object in our map
> >> > script?
> >> > The error message I'm receing is this:
> >> > The service you called did not return valid XML. If you are the system
> >> > administrator, you should look into this, if you are not the system
> >> > administrator you should tell them about this.
> >> > Below I paste three files. First one is my map file. Second one is my
> >> > identify.html file that I was using on Geomoose 2.2. The third one is
> >> > the
> >> > imagemap_record file which I tried to use as a template.
> >> > MAP FILE
> >> > MAP
> >> >     NAME 'ekthemanew'
> >> >     SIZE 800 650
> >> >     STATUS ON
> >> >     EXTENT  2120556.1495784903 3610867.081920644 3593336.723825039
> >> > 5120032.47940209
> >> >     UNITS METERS
> >> >     INCLUDE "../../geomoose_globals.map"
> >> >     TRANSPARENT TRUE
> >> >     IMAGETYPE PNG
> >> >     QUERYMAP
> >> >         STATUS ON
> >> >         STYLE SELECTED
> >> >     END
> >> >     PROJECTION
> >> >         "init=epsg:3857"
> >> >     END
> >> >     WEB
> >> >         QUERYFORMAT "text/html"
> >> >         INCLUDE "../../temp_directory.map"
> >> >         METADATA
> >> >             "wms_title" "WMS Ekthemanew"
> >> >             "wms_onlineresource" "
> http://localhost/cgi-bin/mapserv.exe"
> >> >             "wms_srs" "EPSG:3857"
> >> >             'ows_enable_request' '*'
> >> >         END
> >> >     END
> >> >     LEGEND
> >> >           STATUS ON
> >> >           LABEL
> >> >         TYPE TRUETYPE
> >> >         FONT vera_sans
> >> >         SIZE 8
> >> >         COLOR 0 0 0
> >> >           END
> >> >     END
> >> >     DEBUG ON
> >> >     LAYER
> >> >         DUMP TRUE
> >> >         NAME 'ekthemanew'
> >> >         CONNECTIONTYPE postgis
> >> >         CONNECTION 'host=localhost user=postgres password=1234
> >> > dbname=nath_museum'
> >> >            DATA 'the_geom FROM ekthemanew'
> >> >         TYPE POINT
> >> >         STATUS ON
> >> >         CLASS
> >> >             NAME 'ekthemanew'
> >> >               STYLE
> >> >              SYMBOL 'arxaia'
> >> >              SIZE 15
> >> >             END
> >> >           END
> >> >         #MAXSCALE 1500000
> >> >         HEADER 'imagemap_header.xml'
> >> >         TEMPLATE 'identify_ekthemanew.html'
> >> >         FOOTER 'imagemap_footer.xml'
> >> >         METADATA
> >> >             'identify_record' 'identify_ekthemanew.html'
> >> >             "ows_title" "Ekthemanew"
> >> >             "gml_include_items" "all"
> >> >             "ows_include_items" "all"
> >> >             "gml_exclude_items" "SHAPE_area,SHAPE_len"
> >> >         END
> >> >         TOLERANCEUNITS FEET
> >> >         TOLERANCE 1000000
> >> >     END
> >> > END ## end Map
> >> > IDENTIFY_EKTHEMANEW.HTML FILE
> >> > <!-- MapServer Template -->
> >> > <tr>
> >> > <td colspan="2"><b>Έκθεμα:</b></td>
> >> > </tr>
> >> > <tr>
> >> > <td align="right">Συλλογή:</td>
> >> > <td>[syllogh_ek]</td>
> >> > </tr>
> >> > <tr>
> >> > <td align="right">Περίοδος:</td>
> >> > <td>[xronol_ek]</td>
> >> > </tr>
> >> > <tr>
> >> > <td align="right">Περιγραφή:</td>
> >> > <td>[desc_ek]</td>
> >> > </tr>
> >> > IMAGEMAP_RECORD.XML
> >> > <popup shape='circle' coords='[shpxy xf="," proj=image],5'>
> >> >     <title>Ekthemata</title>
> >> >     <id>Id-[gid]</id>
> >> >     <item title="Nane:">[name_ek]</item>
> >> >     <item title="Collection:">[syllogh_ek]</item>
> >> > </popup>
> >> > _______________________________________________
> >> > Geomoose-users mailing list
> >> > Geomoose-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/1af15d2f/attachment-0001.html>
More information about the Geomoose-users
