[Geomoose-users] Identify error in Geomoose 2.6 (trying to update cersion from geomoose 2.2)
Efstathios Arapostathis e.arapostathis at gmail.com
Wed Oct 17 06:42:06 PDT 2012
Or it does not work any more?
*"........The Query service is intended to replace the itemquery.php
service and eventually the identify service. Both ItemQuery and Identify
may be dropped as of the official 2.0 release. Currently Shapefiles, OGR,
Oracle Spatial, and PostGIS are the only supported layer types for the
General Query Service. If you plan to search a layer other than you may
consider modifying query.php to meet your needs or write another service
entirely"
Please answer me if it is possible, it is urgent
many thanks again,
Stathis
On Wed, Oct 17, 2012 at 4:13 PM, Efstathios Arapostathis <
e.arapostathis at gmail.com> wrote:
> Actually I believe that it just ignores the layer.
> I'm getting the geocoordinates of the spot but I'm not getting any
> attribute-info
> So, I guess that identify service works in the same way *(by creating an
> identify.html file and mentioning it in the map file in Layer's metadata
> map object as:  'identify_record'    'identify.html')*
> It might be something silly that I've forgotten.
> Any idea is welcomed.
> Many many thanks for the responses.
> Stathis
> On Wed, Oct 17, 2012 at 1:10 PM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> I am not so familiar with Mapscript yet, but it seems strange to me
>> that this "reprojectWKT($queryShape->toWkt(), $shape_proj, $map_proj)"
>> returns empty string. Try setting $DEBUG = true at the beginning of
>> the the identify.php, there could be some interesting debugging
>> information in the apache error log.
>> Regards,
>> Matej
>> 2012/10/17 Efstathios Arapostathis <e.arapostathis at gmail.com>:
>> > Hi,
>> >   I've tried firebug, I'm receiving the following message:
>> > Fatal error: Uncaught exception 'MapScriptException' with message
>> 'Unable to
>> > construct shapeObj.' in
>> C:\ms4w\apps\geomoose2\htdocs\php\identify.php:145
>> > Stack trace:
>> > #0 C:\ms4w\apps\geomoose2\htdocs\php\identify.php(145):
>> > ms_shapeObjFromWkt('')
>> > #1 {main}
>> >   thrown in C:\ms4w\apps\geomoose2\htdocs\php\identify.php on line 145
>> > Additional Info: My layer is a PostGIS Layer. I'm attaching the map
>> file and
>> > the identify.html with some changes that I've done.
>> > Any help would be really appreciated.
>> > kind regards,
>> > Stathis
>> > On Tue, Oct 16, 2012 at 9:10 PM, Matej Mailing <mailing at tam.si> wrote:
>> >> Hi,
>> >> try to check to output of the template.php with Firebug and perhaps
>> >> turning the debugging mode on. You will get more information then.
>> >> Regards,
>> >> Matej
>> >> 2012/10/16 Efstathios Arapostathis <e.arapostathis at gmail.com>:
>> >> > Hi,
>> >> >    I've installed the new version of Geomoose 2.6 (I was using
>> version
>> >> > 2.2)
>> >> > but I'm facing problems with the identify service.
>> >> > I've changed my map file (like the firestations.map file which I
>> used as
>> >> > a
>> >> > template).
>> >> > At first I saw that now we have to use a template object in our map
>> >> > script?
>> >> > The error message I'm receing is this:
>> >> > The service you called did not return valid XML. If you are the
>> system
>> >> > administrator, you should look into this, if you are not the system
>> >> > administrator you should tell them about this.
>> >> > Below I paste three files. First one is my map file. Second one is my
>> >> > identify.html file that I was using on Geomoose 2.2. The third one is
>> >> > the
>> >> > imagemap_record file which I tried to use as a template.
>> >> > MAP FILE
>> >> > MAP
>> >> >     NAME 'ekthemanew'
>> >> >     SIZE 800 650
>> >> >     STATUS ON
>> >> >     EXTENT  2120556.1495784903 3610867.081920644 3593336.723825039
>> >> > 5120032.47940209
>> >> >     UNITS METERS
>> >> >     INCLUDE "../../geomoose_globals.map"
>> >> >     TRANSPARENT TRUE
>> >> >     IMAGETYPE PNG
>> >> >     QUERYMAP
>> >> >         STATUS ON
>> >> >         STYLE SELECTED
>> >> >     END
>> >> >     PROJECTION
>> >> >         "init=epsg:3857"
>> >> >     END
>> >> >     WEB
>> >> >         QUERYFORMAT "text/html"
>> >> >         INCLUDE "../../temp_directory.map"
>> >> >         METADATA
>> >> >             "wms_title" "WMS Ekthemanew"
>> >> >             "wms_onlineresource" "
>> http://localhost/cgi-bin/mapserv.exe"
>> >> >             "wms_srs" "EPSG:3857"
>> >> >             'ows_enable_request' '*'
>> >> >         END
>> >> >     END
>> >> >     LEGEND
>> >> >           STATUS ON
>> >> >           LABEL
>> >> >         TYPE TRUETYPE
>> >> >         FONT vera_sans
>> >> >         SIZE 8
>> >> >         COLOR 0 0 0
>> >> >           END
>> >> >     END
>> >> >     DEBUG ON
>> >> >     LAYER
>> >> >         DUMP TRUE
>> >> >         NAME 'ekthemanew'
>> >> >         CONNECTIONTYPE postgis
>> >> >         CONNECTION 'host=localhost user=postgres password=1234
>> >> > dbname=nath_museum'
>> >> >            DATA 'the_geom FROM ekthemanew'
>> >> >         TYPE POINT
>> >> >         STATUS ON
>> >> >         CLASS
>> >> >             NAME 'ekthemanew'
>> >> >               STYLE
>> >> >              SYMBOL 'arxaia'
>> >> >              SIZE 15
>> >> >             END
>> >> >           END
>> >> >         #MAXSCALE 1500000
>> >> >         HEADER 'imagemap_header.xml'
>> >> >         TEMPLATE 'identify_ekthemanew.html'
>> >> >         FOOTER 'imagemap_footer.xml'
>> >> >         METADATA
>> >> >             'identify_record' 'identify_ekthemanew.html'
>> >> >             "ows_title" "Ekthemanew"
>> >> >             "gml_include_items" "all"
>> >> >             "ows_include_items" "all"
>> >> >             "gml_exclude_items" "SHAPE_area,SHAPE_len"
>> >> >         END
>> >> >         TOLERANCEUNITS FEET
>> >> >         TOLERANCE 1000000
>> >> >     END
>> >> > END ## end Map
>> >> > IDENTIFY_EKTHEMANEW.HTML FILE
>> >> > <!-- MapServer Template -->
>> >> > <tr>
>> >> > <td colspan="2"><b>Έκθεμα:</b></td>
>> >> > </tr>
>> >> > <tr>
>> >> > <td align="right">Συλλογή:</td>
>> >> > <td>[syllogh_ek]</td>
>> >> > </tr>
>> >> > <tr>
>> >> > <td align="right">Περίοδος:</td>
>> >> > <td>[xronol_ek]</td>
>> >> > </tr>
>> >> > <tr>
>> >> > <td align="right">Περιγραφή:</td>
>> >> > <td>[desc_ek]</td>
>> >> > </tr>
>> >> > IMAGEMAP_RECORD.XML
>> >> > <popup shape='circle' coords='[shpxy xf="," proj=image],5'>
>> >> >     <title>Ekthemata</title>
>> >> >     <id>Id-[gid]</id>
>> >> >     <item title="Nane:">[name_ek]</item>
>> >> >     <item title="Collection:">[syllogh_ek]</item>
>> >> > </popup>
>> >> > _______________________________________________
>> >> > Geomoose-users mailing list
>> >> > Geomoose-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/874a94ff/attachment.html>
More information about the Geomoose-users mailing list
