[Geomoose-users] Dynamic Zoom
Jim Klassen
klassen.js at gmail.com
Wed Oct 17 10:24:09 PDT 2012
My thoughts would be to implement this as part of a custom tab mostly
because I am worried about the future safeness of hooking into UI
elements outside of a new tab. UI wise, it is more obvious to the user
the way it is.
Do we have a clean/future safe way for extensions to hook into existing
UI elements other than creating a tab?
On 10/17/2012 11:33 AM, Dan Little wrote:
> I think it'd be good to look into the FilteringSelect Dijit for
> implementing something. :-) If you need, I could try to dig up some
> code for it but it's not terribly difficult to code.
> *From:* "Bistrais, Bob" <Bob.Bistrais at maine.gov>
> *To:* "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>;
> Brian Fischer <bfischer at houstoneng.com>;
> "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
> *Sent:* Wednesday, October 17, 2012 11:30 AM
> *Subject:* Re: [Geomoose-users] Dynamic Zoom
> I’m not currently working on such an extension (tried a few
> unsuccessful attempts), could certainly use this functionality.
> Agree with Bob’s points, the highlighting in particular.
> *From:*geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of
> *Basques, Bob (CI-StPaul)
> *Sent:* Wednesday, October 17, 2012 12:14 PM
> *To:* Brian Fischer; geomoose-users at lists.osgeo.org
> Brian,
> I just tried it out and went to >> Municipalities >> Frost.
> Highlighting of the Frost wasn’t obvious, upon closer inspection
> though, I see the green outline (of Frost?). Would it make any
> sense to add a highlighting option as a result set, possibly even
> adding a label and or popup as optional configs.
> When the list comes back from the Municipality selection (I assume
> I can only select one at a time) you should just zoom
> automatically to the location, the GO button could go away then.
> Being able to select more than one item from the list might be a
> good option to add if it is not already there. Probably not needed
> for Cities or municipality selections, but for other items it
> might be useful.
> Works real nice as is too. :c) .
> Bobb
> <mailto:geomoose-users-bounces at lists.osgeo.org>
> <mailto:[mailto:geomoose-users-bounces at lists.osgeo.org]> *On
> Behalf Of *Brian Fischer
> *Sent:* Wednesday, October 17, 2012 11:04 AM
> *To:* geomoose-users at lists.osgeo.org
> <mailto:geomoose-users at lists.osgeo.org>
> *Subject:* [Geomoose-users] Dynamic Zoom
> We have a couple viewers that were using a “Dynamic Zoom To”. It
> looks like this code was re-written into an extension
> (http://www.geomoose.org/extensions/DynamicZoom.html), but that it
> only would work with a GeoMoose 2.4 interface because it is not
> using the new Dojo interface and dropdown Dijit that is being used
> for Zoom To in 2.6. So in conclusion this is not working with GM 2.6.
> Before we try to tackle this code I just want to make sure no one
> else has worked on upgrading this extension. Also do others like
> how the Dynamic Zoom to’s work? If you want to see an example take
> a look at the Zoom to in http://faribault.houstoneng.net/ . Any
> other suggestions for an improved user experience that we should
> consider?
> Thanks,
> Brian
> *Brian Fischer, CFM*
> Principal | GIS Project Manager
> *O*763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
> cid:image001.jpg at 01CC3702.356B79C0
> 6901 E Fish Lake Rd. , Suite 140 • Maple Grove, MN •55369
> *www.houstoneng.com* <http://www.houstoneng.com/>**
> This entire message (including all forwards and replies) and any
> attachments are for the sole use of the intended recipient(s) and
> may contain proprietary, confidential, trade secret, work-product,
> attorney-client or privileged information. Any unauthorized
> review, use, disclosure or distribution is prohibited and may be a
> violation of law. If you are not the intended recipient, please
> contact the sender by reply email and destroy all copies of the
> original message.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
