[Geomoose-users] Dynamic Zoom
Dan Little
danlittle at yahoo.com
Wed Oct 17 11:27:01 PDT 2012
I think that's apart of the YMMV warning that should come with writing Extensions. However, that's not a going to be a popular opinion.
We've kept the 'zoom box' there since version 1.4, I'm not sure it's going anywhere.
>________________________________
> From: Jim Klassen <klassen.js at gmail.com>
>To: geomoose-users at lists.osgeo.org
>Sent: Wednesday, October 17, 2012 12:24 PM
>Subject: Re: [Geomoose-users] Dynamic Zoom
>My thoughts would be to implement this as part of a custom tab mostly
>because I am worried about the future safeness of hooking into UI
>elements outside of a new tab. UI wise, it is more obvious to the user
>the way it is.
>Do we have a clean/future safe way for extensions to hook into existing
>UI elements other than creating a tab?
>On 10/17/2012 11:33 AM, Dan Little wrote:
>> I think it'd be good to look into the FilteringSelect Dijit for
>> implementing something. :-) If you need, I could try to dig up some
>> code for it but it's not terribly difficult to code.
>> *From:* "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>> *To:* "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>;
>> Brian Fischer <bfischer at houstoneng.com>;
>> "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>> *Sent:* Wednesday, October 17, 2012 11:30 AM
>> *Subject:* Re: [Geomoose-users] Dynamic Zoom
>> I’m not currently working on such an extension (tried a few
>> unsuccessful attempts), could certainly use this functionality.
>> Agree with Bob’s points, the highlighting in particular.
>> *From:*geomoose-users-bounces at lists.osgeo.org
>> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of
>> *Basques, Bob (CI-StPaul)
>> *Sent:* Wednesday, October 17, 2012 12:14 PM
>> *To:* Brian Fischer; geomoose-users at lists.osgeo.org
>> Brian,
>> I just tried it out and went to >> Municipalities >> Frost.
>> Highlighting of the Frost wasn’t obvious, upon closer inspection
>> though, I see the green outline (of Frost?). Would it make any
>> sense to add a highlighting option as a result set, possibly even
>> adding a label and or popup as optional configs.
>> When the list comes back from the Municipality selection (I assume
>> I can only select one at a time) you should just zoom
>> automatically to the location, the GO button could go away then.
>> Being able to select more than one item from the list might be a
>> good option to add if it is not already there. Probably not needed
>> for Cities or municipality selections, but for other items it
>> might be useful.
>> Works real nice as is too. :c) .
>> Bobb
>> <mailto:geomoose-users-bounces at lists.osgeo.org>
>> <mailto:[mailto:geomoose-users-bounces at lists.osgeo.org]> *On
>> Behalf Of *Brian Fischer
>> *Sent:* Wednesday, October 17, 2012 11:04 AM
>> *To:* geomoose-users at lists.osgeo.org
>> <mailto:geomoose-users at lists.osgeo.org>
>> *Subject:* [Geomoose-users] Dynamic Zoom
>> We have a couple viewers that were using a “Dynamic Zoom To”. It
>> looks like this code was re-written into an extension
>> (http://www.geomoose.org/extensions/DynamicZoom.html), but that it
>> only would work with a GeoMoose 2.4 interface because it is not
>> using the new Dojo interface and dropdown Dijit that is being used
>> for Zoom To in 2.6. So in conclusion this is not working with GM 2.6.
>> Before we try to tackle this code I just want to make sure no one
>> else has worked on upgrading this extension. Also do others like
>> how the Dynamic Zoom to’s work? If you want to see an example take
>> a look at the Zoom to in http://faribault.houstoneng.net/ . Any
>> other suggestions for an improved user experience that we should
>> consider?
>> Thanks,
>> Brian
>> *Brian Fischer, CFM*
>> Principal | GIS Project Manager
>> *O*763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
>> cid:image001.jpg at 01CC3702.356B79C0
>> 6901 E Fish Lake Rd. , Suite 140 • Maple Grove, MN •55369
>> *www.houstoneng.com* <http://www.houstoneng.com/>**
>> This entire message (including all forwards and replies) and any
>> attachments are for the sole use of the intended recipient(s) and
>> may contain proprietary, confidential, trade secret, work-product,
>> attorney-client or privileged information. Any unauthorized
>> review, use, disclosure or distribution is prohibited and may be a
>> violation of law. If you are not the intended recipient, please
>> contact the sender by reply email and destroy all copies of the
>> original message.
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121017/ab7a8100/attachment-0001.html>
More information about the Geomoose-users
