[Geomoose-users] Layer Display Error
Efstathios Arapostathis
e.arapostathis at gmail.com
Fri Oct 19 08:42:34 PDT 2012
Thank you Eli for the response, I'll try it for sure next time I'll face
similar issues.
On Fri, Oct 19, 2012 at 5:09 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> On Fri, Oct 19, 2012 at 1:34 AM, Efstathios Arapostathis <
> e.arapostathis at gmail.com> wrote:
>> Hi guys,
>> Apparently I have not used geomoose for a long period of time, so I'm
>> stucked again in issues that I have solved in the past.
>> I was wondering if you could provide me with some feedback. I'm having
>> problems in displaying a postgis layer in geomoose 2.6. I'm getting a pink
>> image and when I'm trying to follow the link (from mozilla firefox on the
>> sub menu tools-->page info-->multimedia) no error message is provided.
>> Instead a popup window appears in order to save mapserv.exe file(!!)
> Save mapserv.exe and open it with a text editor. It is a text/xml file
> with the wrong extension, it will report some error.
> Eli
>> I enabled debug in the map file and this is the log I'm receiving. I
>> cannot really understand it. Could anyone help me please?
>> [Fri Oct 19 11:20:39 2012].971000 CGI Request 1 on process 4992
>> [Fri Oct 19 11:20:37 2012].936000 CGI Request 1 on process 3524
>> [Fri Oct 19 11:20:37 2012].940000 msDrawMap(): rendering using
>> outputformat named agg/png (AGG/PNG).
>> [Fri Oct 19 11:20:40 2012].106000 msPostGISLayerWhichShapes(): Query
>> error. Error (ERROR: relation "agenda" does not exist
>> LINE 1: ...e_2D("the_geom"),'NDR'),'hex') as geom,"gid" from Agenda whe...
>> ) executing query: select
>> encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as geom,"gid" from
>> Agenda where the_geom && GeomFromText('POLYGON((2646964.79596457
>> 4577985.29374734,2646964.79596457 4584071.59212366,2657943.06415043
>> 4584071.59212366,2657943.06415043 4577985.29374734,2646964.79596457
>> 4577985.29374734))',find_srid('','Agenda','the_geom'))
>> [Fri Oct 19 11:20:40 2012].106000 msDrawMap(): Image handling error.
>> Failed to draw layer named 'Agenda'.
>> [Fri Oct 19 11:20:38 2012].473000 CGI Request 1 on process 4848
>> [Fri Oct 19 11:20:38 2012].619000 msDrawMap(): rendering using
>> [Fri Oct 19 11:20:40 2012].199000 msPostGISLayerWhichShapes(): Query
>> "Agenda" Is the name of the Table of the "CulturalGIS" database. It is a
>> POINT PostGIS Layer, I'm attaching the map file.
>> Thanks in advance for any responses
>> Stathis
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121019/40030371/attachment.html>
More information about the Geomoose-users
