[Geomoose-users] Fwd: Highlighting issue (Mapserver layer)
Brian Fischer
bfischer at houstoneng.com
Mon Oct 22 18:03:55 PDT 2012
Matej,
Was this from a point layer? I see the line layer has no style or symbol defined either. Do you know whether that works?
Can you send us the corrected highlight.map file you used so I can get the source files updated?
Thanks!
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
Sent: Tuesday, October 16, 2012 4:54 PM
To: Jim Klassen
Cc: GeoMOOSE Users List
Subject: Re: [Geomoose-users] Fwd: Highlighting issue (Mapserver layer)
You were right, the errors were caused due to a stupid typo that was contained in the generated mapfile and the blank highlight output was caused because I had no symbol defined to be shown. After changing it, everything works as smooth as possible :-)
Thanks.
Regards,
Matej
2012/10/16 Jim Klassen <klassen.js at gmail.com>:
> On 10/16/2012 12:30 PM, Matej Mailing wrote:
>> Now when enabling logging on php/itemquery/highlight.map I see that
>> features are not added to the layer as I was thinking.
>> I get
>> [Tue Oct 16 17:20:35 2012].974701 getSymbol(): Symbol definition
>> error. Parsing error near (upper):(line 220) and then a number of
>> those lines:
> This means there is a syntax error on line 220 of the mapfile. Now
> the question is, "Which mapfile?" I'm guessing the mapfile generated
> in query.php around line 428.
> Try looking at $mapfile (print it to stderr or dump it to a temp file
> and open it in an editor (after the processTemplate line and before
> the ms_newMapObjFromString line). My guess is there is a problem on
> line
> 220 of that.
>> [Tue Oct 16 17:20:37 2012].142038 msBuildOnlineResource(): CGI error.
>> Impossible to establish server URL.
>> [Tue Oct 16 17:20:37 2012].142064 msOWSGetOnlineResource(): CGI error.
>> Impossible to establish server URL. Please set "onlineresource"
>> metadata.
>> I have set 'ows_onlineresource' and 'ows_service_onlineresource' to
>> 'http://ip/cgi-bin/mapserv?' and no matter what I do (I even set
>> wms*,
>> wfs* and wcs*). What bothers me and perhaps is the cause of the
>> errors, is the first (Symbol definition error. Parsing error near
>> (upper)) error. Could this error cause the mapserver to stop parsing
>> the mapfile and thus ignoring my multiple *onlineresource metadata?
>> Does anyone else experiences this issue?
>> I really want to move forward on this one, but I seem to be lost.
>> Regards,
>> Matej
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
