[Geomoose-users] Problem with "All" layers specified in the catalog
Matej Mailing
mailing at tam.si
Fri Oct 26 03:15:00 PDT 2012
I remember I had to add GROUP "all" to all the layers we are
referencing to as "all" and that solved the issue.
Regards,
Matej
2012/10/25 Eli Adam <eadam at co.lincoln.or.us>:
> On Thu, Oct 25, 2012 at 10:22 AM, Ed Boesenberg
> <eboesenberg at niraengineers.com> wrote:
>> I have 4 layers within a map file and I listed each one in the map source
>> but in the catalog I tried to use "layer/all" but GeoMoose 2.6 did not
>> render the layer. Is "layer/all" still valid in the map source or layer
>> catalog? I was only able to get it to work by listing each layer in the
>> catalog separated by a colons.
> There is an FAQ about this,
> http://www.geomoose.org/docs/faq.html#why-doesn-t-layers-all-work-anymore
> Once you investigate it, please offer an revisions needed to the FAQ.
> Thanks, Eli
>> Ed
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
