[Geomoose-users] Problem with "All" layers specified in the catalog
Brian Fischer
bfischer at houstoneng.com
Fri Oct 26 06:15:05 PDT 2012
Just one note, this works for displaying but if you want to identify on those layers then you have to specify each one in the map book. At least that is what I am experiencing.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
Sent: Friday, October 26, 2012 5:15 AM
To: eadam at co.lincoln.or.us
Cc: Ed Boesenberg; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Problem with "All" layers specified in the catalog
I remember I had to add GROUP "all" to all the layers we are referencing to as "all" and that solved the issue.
Regards,
Matej
2012/10/25 Eli Adam <eadam at co.lincoln.or.us>:
> On Thu, Oct 25, 2012 at 10:22 AM, Ed Boesenberg
> <eboesenberg at niraengineers.com> wrote:
>> I have 4 layers within a map file and I listed each one in the map
>> source but in the catalog I tried to use "layer/all" but GeoMoose
>> 2.6 did not render the layer. Is "layer/all" still valid in the map
>> source or layer catalog? I was only able to get it to work by
>> listing each layer in the catalog separated by a colons.
> There is an FAQ about this,
> http://www.geomoose.org/docs/faq.html#why-doesn-t-layers-all-work-anym
> ore
> Once you investigate it, please offer an revisions needed to the FAQ.
> Thanks, Eli
>> Ed
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
