[Geomoose-users] UNSUBSCRIBE
David Rosell
david.rosell at ietcat.org
Tue Oct 30 05:03:41 PDT 2012
-----Mensaje original-----
De: geomoose-users-bounces at lists.osgeo.org
[mailto:geomoose-users-bounces at lists.osgeo.org] En nombre de Matej Mailing
Enviado el: viernes, 26 de octubre de 2012 12:15
Para: eadam at co.lincoln.or.us
CC: Ed Boesenberg; geomoose-users at lists.osgeo.org
Asunto: Re: [Geomoose-users] Problem with "All" layers specified in the
catalog
I remember I had to add GROUP "all" to all the layers we are referencing to
as "all" and that solved the issue.
Regards,
Matej
2012/10/25 Eli Adam <eadam at co.lincoln.or.us>:
> On Thu, Oct 25, 2012 at 10:22 AM, Ed Boesenberg
> <eboesenberg at niraengineers.com> wrote:
>> I have 4 layers within a map file and I listed each one in the map
>> source but in the catalog I tried to use "layer/all" but GeoMoose
>> 2.6 did not render the layer. Is "layer/all" still valid in the map
>> source or layer catalog? I was only able to get it to work by
>> listing each layer in the catalog separated by a colons.
> There is an FAQ about this,
> http://www.geomoose.org/docs/faq.html#why-doesn-t-layers-all-work-anym
> ore
> Once you investigate it, please offer an revisions needed to the FAQ.
> Thanks, Eli
>> Ed
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
