[Geomoose-users] Legend not visible with maxscaledenom set
Anderson, Dean
anderson.dean at co.polk.or.us
Tue Sep 11 10:57:34 PDT 2012
Bob
Also confirmed this and will submit a ticket as this is a bug.
Dean
On Fri, May 25, 2012 at 12:28 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>wrote:
> I am dabbling with the GM 2.6 release candidate and found a quirk. At
> first I thought it was a problem with MapServer 6.0.2, but now I’m
> suspecting GM. ****
> I have map layers that have a Maxscaledenom set. The legends for these
> layers were not displaying, even when zoomed into the visible scale range.
> I am now finding that, with the Maxscaledenom set, if the layer is turned
> off until you zoom into the Maxscaledenom, the legend will display when you
> turn it on. If you have the layer on when outside the maxscaledenom, then
> zoom into the visible range, the legend does not show unless you turn the
> layer off, then on again. It’s like you need to “refresh” the TOC to get
> the legend to show.****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120911/0357e561/attachment.html>
More information about the Geomoose-users
