[Geomoose-users] Identify not working
Eli Adam
eadam at co.lincoln.or.us
Wed Sep 12 16:00:32 PDT 2012
Matej,
On Wed, Sep 12, 2012 at 3:52 PM, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> I have a layer where I have added
> METADATA
> 'identify_record' 'templates/identify.html'
> END
> and created a file in the subdirectory of the directory where the map
> file is. Identify service is active since when I click to some point I
Does your template start with:
<!-- MapServer Template -->
> get the coordinates. This layer can be the only layer turned on in the
> Catalog, but I still get no identify results and the message
> containing the coordinates seems to be used.
Can you review this draft updated documentation and see if it helps?
http://geomoose.org/trunk/howto/identify.html
HTH, Eli
> What am I doing wrong? I have been pulling my hair out for quite some
> hours now ...
> Thanks for all the ideas.
> Matej
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
