[Geomoose-users] Identify not working
Matej Mailing
mailing at tam.si
Wed Sep 12 16:24:12 PDT 2012
I have followed all 3 points, but with no success. I still get the
coordinates and that's it ...
Now I have removed all the fields from the template file (that begins
with the <!-- MapServer Template -->) so it only outputs some "hello
world text", but it still doesn't work. I have now found a
metadata="true" option available when defining the layer in the
mapbook file, but also with this set to true it doesn't work. I have
also added only this layer to be used for identify via <input
type="hidden" name="layers" value="..."/> with no result :/
What is the best way to debug this issue?
Thanks for any ideas in advance ....
Matej
2012/9/13 Eli Adam <eadam at co.lincoln.or.us>:
> Matej,
> On Wed, Sep 12, 2012 at 3:52 PM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> I have a layer where I have added
>> METADATA
>> 'identify_record' 'templates/identify.html'
>> END
>> and created a file in the subdirectory of the directory where the map
>> file is. Identify service is active since when I click to some point I
> Does your template start with:
>> get the coordinates. This layer can be the only layer turned on in the
>> Catalog, but I still get no identify results and the message
>> containing the coordinates seems to be used.
> Can you review this draft updated documentation and see if it helps?
> http://geomoose.org/trunk/howto/identify.html
> HTH, Eli
>> What am I doing wrong? I have been pulling my hair out for quite some
>> hours now ...
>> Thanks for all the ideas.
>> Matej
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
