[Geomoose-users] Identify not working
Anderson, Dean
anderson.dean at co.polk.or.us
Wed Sep 19 13:24:19 PDT 2012
So - what does your map file look like?
THanks
Dean
On Wed, Sep 19, 2012 at 1:20 PM, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> wms_* entries were commented out (non-wms_* were not), but also after
> uncommenting them the situation is the same. When checking the POST
> parameters for identify.php with Firebug, there is no projection. The
> projection file (Javascript) is successfully loaded on the site and
> the EPSG:4326 is set both in mapbook.xml and settings.ini (in [map]
> section).
> The parcels demo has data stored in SHP and we are using PostGIS for
> it. I have gone through both map files and the only difference is that
> in the WEB METADATA of our mapfile we have wms_title, wms_srs and
> wms_enable_request and in parcels mapfile there are ows_* tags ...
> Thanks,
> Matej
> 2012/9/19 Brent Fraser <bfraser at geoanalytic.com>:
> > Does your settings.ini file have entries like
> > [identify]
> > identify_header=identify/header.html
> > identify_footer=identify/footer.html
> > wms_header=identify/wms_header.html
> > wms_record=identify/wms_record.html
> > wms_footer=identify/wms_footer.html
> > and do the files pointed to by the wms_* entries exist in the htdocs\php
> > folder?
> > Best Regards,
> > Brent Fraser
> > On 9/19/2012 1:47 PM, Matej Mailing wrote:
> >> Just now I have found out that in my case I have no "projection"
> >> parameter sent into the identify.php when comparing to the working
> >> parcels sample. We are using EPSG:4326 - could this be a problem?
> >> Thanks,
> >> Matej
> >> 2012/9/19 Matej Mailing <mailing at tam.si>:
> >>> Hi all,
> >>> I was able to get parcels identification working, but my layer still
> >>> doesn't work. When enabling debug messages in identify.php, I get the
> >>> followint output:
> >>> "Notice: Undefined index: wms_header in /path/php/identify.php on line
> >>> 116
> >>> Warning: file(): Filename cannot be empty in /path/php/identify.php on
> >>> line 116
> >>> Warning: implode(): Invalid arguments passed in /path/php/identify.php
> >>> on line 116
> >>> Notice: Undefined index: wms_record in /path/php/identify.php on line
> 117
> >>> line 117
> >>> on line 117
> >>> Notice: Undefined index: wms_footer in /path/php/identify.php on line
> 118
> >>> line 118
> >>> on line 118
> >>> Warning: mapObj::queryByPoint(): [MapServer Error]: msQueryByPoint():
> >>> No matching record(s) found.
> >>> in /path/php/identify.php on line 170"
> >>> When turning off the debug mode, I get the same output as mentioned
> >>> before: just coordinates of the point.
> >>> Thanks for any ideas,
> >>> Matej
> >>> 2012/9/13 Eli Adam <eadam at co.lincoln.or.us>:
> >>>> On Wed, Sep 12, 2012 at 4:24 PM, Matej Mailing <mailing at tam.si>
> wrote:
> >>>>> Hi,
> >>>>> I have followed all 3 points, but with no success. I still get the
> >>>>> coordinates and that's it ...
> >>>> If you started with the demo, does identify on the parcels work?
> >>>>> Now I have removed all the fields from the template file (that begins
> >>>>> with the <!-- MapServer Template -->) so it only outputs some "hello
> >>>>> world text", but it still doesn't work. I have now found a
> >>>>> metadata="true" option available when defining the layer in the
> >>>>> mapbook file, but also with this set to true it doesn't work. I have
> >>>>> also added only this layer to be used for identify via <input
> >>>>> type="hidden" name="layers" value="..."/> with no result :/
> >>>>> What is the best way to debug this issue?
> >>>> Firefox/firebug could be a good way to start. Using the firebug
> >>>> console on the online demo leads to seeing things like:
> >>>> post
> >>>> dojo.preventCache 1347492736022
> >>>> layers
> blank%3Ablank/blank%3Aborders%3Aborders/city_labels%3Aborders/county_labels%3Aborders/city_poly%3Aborders/county_borders%3Aparcels%3Aparcels/parcels%3Asketch
> >>>> projection EPSG%3A3857
> >>>> shape POINT%28-10372969.112863%205552707.7829098%29
> >>>> Source
> layers=blank%253Ablank%2Fblank%253Aborders%253Aborders%2Fcity_labels%253Aborders%2Fcounty_labels%253Aborders%2Fcity_poly%253Aborders%2Fcounty_borders%253Aparcels%253Aparcels%2Fparcels%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-10372969.112863%25205552707.7829098%2529&dojo.preventCache=1347492736022
> >>>> response
> >>>> <results><script> GeoMOOSE.clearLayerParameters('highlight');
> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CDATA[<!--
> >>>> Detailed information for the area you clicked on the map...
> >>>> <table border="0">
> >>>> <tr>
> >>>> <td colspan="2"><b><u>Ground Coordinates</u></b>
> >>>> <br>
> >>>> <b>X: </b>485549.182735
> >>>> <br>
> >>>> <b>Y: </b>4934226.01043</td>
> >>>> </tr>
> >>>> <tr>
> >>>> <td> </td>
> >>>> <td> </td>
> >>>> </tr>
> >>>> </table>
> >>>> <table border="0" cellpadding="1" cellspacing="2">
> >>>> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
> >>>> <tr>
> >>>> <td align="right"><b>PIN:</b></td>
> >>>> <td>130260001175 <a
> >>>> href="javascript:GeoMOOSE.startService('feature_report', {'PIN' :
> >>>> '130260001175', 'src' : 'parcels/parcels'})">Report</a></td>
> >>>> </tr>
> >>>> <tr>
> >>>> <td align="right"><b>Owner Name:</b></td>
> >>>> <td>Thaddeus Garcia</td>
> >>>> </tr>
> >>>> <tr>
> >>>> <td align="right"><b>Est. Market Value:</b></td>
> >>>> <td>1178700</td>
> >>>> </tr>
> >>>> <tr>
> >>>> <td align="right"><b>Acres:</b></td>
> >>>> <td>154.37</td>
> >>>> </tr>
> >>>> <tr>
> >>>> <td> </td>
> >>>> <td> </td>
> >>>> </tr>
> >>>> ]]></html><footer><![CDATA[<b>Disclaimer: This information is being
> >>>> distributed as demonstation data only. You should not use the data
> >>>> for any other purposes.</b>
> >>>> ]]></footer></results>
> >>>> You can do the same with your site and see exactly what is coming back
> >>>> in the response. Posting more specific details (relevant parts of
> >>>> mapbook.xml, ogrinfo of datasource) or providing a link to your
> >>>> website might make it easier for people to make suggestions. Getting
> >>>> the parcels example working correctly and then closely matching the
> >>>> parcels set can be a starting place. Also confirm that relative paths
> >>>> are correct.
> >>>> Best Regards, Eli
> >>>>> Thanks for any ideas in advance ....
> >>>>> Matej
> >>>>>> Matej,
> >>>>>> On Wed, Sep 12, 2012 at 3:52 PM, Matej Mailing <mailing at tam.si>
> wrote:
> >>>>>>> Hi,
> >>>>>>> I have a layer where I have added
> >>>>>>> METADATA
> >>>>>>> 'identify_record'
> >>>>>>> 'templates/identify.html'
> >>>>>>> END
> >>>>>>> and created a file in the subdirectory of the directory where the
> map
> >>>>>>> file is. Identify service is active since when I click to some
> point
> >>>>>>> I
> >>>>>> Does your template start with:
> >>>>>>> get the coordinates. This layer can be the only layer turned on in
> >>>>>>> the
> >>>>>>> Catalog, but I still get no identify results and the message
> >>>>>>> containing the coordinates seems to be used.
> >>>>>> Can you review this draft updated documentation and see if it helps?
> >>>>>> http://geomoose.org/trunk/howto/identify.html
> >>>>>> HTH, Eli
> >>>>>>> What am I doing wrong? I have been pulling my hair out for quite
> some
> >>>>>>> hours now ...
> >>>>>>> Thanks for all the ideas.
> >>>>>>> Matej
> >>>>>>> _______________________________________________
> >>>>>>> Geomoose-users mailing list
> >>>>>>> Geomoose-users at lists.osgeo.org
> >>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120919/fd633e7b/attachment.html>
More information about the Geomoose-users
