[Geomoose-users] GeoMoose core changes?
Eli Adam
eadam at co.lincoln.or.us
Tue Sep 25 19:25:18 PDT 2012
Jim,
Comments a ways below (but kept complete for context).
On Sat, Sep 22, 2012 at 12:46 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> I meant to reply to the list.
> Begin forwarded message:
> From: Jim Klassen <klassen.js at gmail.com>
> Date: September 21, 2012 23:30:25 CDT
> To: Brian Fischer <bfischer at houstoneng.com>
> Subject: Re: [Geomoose-users] GeoMoose core changes?
> Brian,
> Thanks for the feedback.
> My intent is for the visible layers to be built as an extension. However,
> to do this without breaking the rules, I need some changes in the core that
> expose more functionality to extensions. The changes I need shouldn't
> impact existing use of the application. Alternatively, it might make some
> sense for it to end up in core because of all the bits it needs to hook
> into. In either case there is nothing that would require anyone to
> use/enable it.
> I don't expect it will be applicable to many sites since defining what
> should be in visible layers (remembering it reflects the stacked z-order as
> rendered) becomes very ugly if you are using the feature that allows one
> catalog layer to be linked to multiple map-source layer (that helps with
> label stacking) as one catalog layer may need to be in 2 or more places.
> This is because it has to operate at the map-source level rather than the
> catalog layer level as this is ultimately what become OpenLayers layers.
> Obviously, such behavior could be very confusing to end users with some
> mapbooks.
> Not to confuse things too much, because I think the Visible Layers tab can
> be useful separate from the CSW catalog, but in my current use case I could
> almost see the existing catalog tab as what would be hidden. As is, we are
> keeping it for now to hold the basemap type layers as the bulk (potentially
> 1000's) of the layers are available from the searchable CSW catalog.
> Jim
> On Sep 21, 2012, at 22:21, Brian Fischer <bfischer at houstoneng.com> wrote:
> HI Jim,
> In general these things seem like really nice enhancements to the core. The
> only things that I was not clear on is if you are proposing the Visible
> Layers tab be in core and the default way GeoMoose would work or if that
> would be the extension? I personally am not a big fan of 2 tabs with layers
> in it as I think it is awkward for a user to have to switch back and forth
> all the time. Would these enhancements work on the layers/map-sources in
> the main TOC tab as well? Like ability to turn on/off layers. Obviously
> the Up/Down Z-Order stuff would be difficult with groups and nested groups.
> One idea is instead of another tab maybe you could put the visible layers in
> a dojo widget such as a popup dialog that allows users to move layers up
> and down. Just a thought as another way to get the same functionality but
> without the 2 tabs.
> All and all good ideas, just need to clarify the visible tab is in core or
> an extension.
> Brian Fischer, CFM
> Principal | GIS Project Manager
> Houston Engineering, Inc.
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> -----Original Message-----
> From: geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim Klassen
> Sent: Friday, September 21, 2012 5:19 PM
> To: geomoose-users at lists.osgeo.org List
> Subject: [Geomoose-users] GeoMoose core changes?
> I am working on Add (WMS) to Map from my CSW Catalog extension and a Visible
> Layers extensions and I found I need to make some changes to core code.
> Taking one step back... I need a way from my CSW catalog to add new layers
> (map-sources) to the map at runtime. I also need a way to control these
> layers once they are added. I have decided that it makes more sense to
> create a visible layers tab (like was in GeoMoose 1.x) that can handle these
> dynamic layers as well as provide a more intuitive interface for the Up/Down
> Z-Order problem introduced in 2.x. (For my purposes a layer == a map-source
> for now, although the nesting of the layers within the map-sources could
> potentially be added later).
> To do this I need a way to add a map-source at runtime and a way to hook
> into the events such that I can update my Visible Layers tab when something
> changes (from the regular catalog or from the CSW catalog). I also need to
> be able to trigger events from the Visible Layers tab (such as move
> up/down/turn layer off) etc. I think the event framework is (mostly) in
> place already. Also, adding a layer on the fly directly to the OpenLayers
> map object works, but then it isn't part of what GeoMoose knows about (for
> instance GeoMoose.setVisibility would fail because it doesn't have a
> "path").
Adding layers at runtime could be useful for many things. Can a
dynamic layer adding general function also be
used for a dynamic wfs adding function in select/query or other
capacities? This could also be lying the groundwork for 'upload a
shapefile' functionality down the road. However, on the server side,
that would require ogr to detect the projection, writing a map file of
sorts, and other aspects but this could be the beginning.
Best Regards, Eli
> At a minimum it looks like I need to change some stuff around in
> Application.js
> For starters I have split configureMapSources into it's outer loop and an
> inner function that actually creates the map-source. I need this so I can
> call the later directly from my extensions.
> At this point I am looking for thoughts/ideas on how to best not mess things
> up.
> Jim
More information about the Geomoose-users
