[Geomoose-users] Just installed Geomoose... 1st problem
James Klassen
klassen.js at gmail.com
Thu Feb 21 09:29:39 PST 2013
Use type WMS. Type mapserver is deprecated.
Also, IIRC the PHP files with Geomoose 2.6 is expecting MapServer 6.
On Feb 21, 2013 9:48 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it> wrote:
> Hi all.
> I've just installed GeoMoose 2.6 over Mapserver 5.6 with PHPMapscript on a
> Debian 6 Squeeze machine with Apache 2.2.16 and PHP 5.3.3
> I've a problem with the demo on my machine, in particular with
> <map-sources> of type="mapserver":
> I can't see neither the shape on the map nor the legend with the line
> element in the catalog. Background layers such as google o yahoo work
> good: I can see and navigate them.
> I've configured Mapserver with all the parameters described in the
> documentation (agg, freetype, gdal, and so on: here's my server response
> #/usr/lib/cgi-bin/mapserv -v
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> Also required PHP extensions are loaded (phpinfo())
> Changing locale_settings.ini for mapserver_url from /cgi-bin/mapserv to
> /usr/lib/cgi-bin/mapserv has no effect
> Maybe I must change the rights of some folders?
> Anyone had the same problem?
> Thanks a lot!
> With Best Regards, Carlo
> ______________________________**_________________
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/geomoose-**users<http://lists.osgeo.org/mailman/listinfo/geomoose-users>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130221/218590c1/attachment.html>
More information about the Geomoose-users
