[Geomoose-users] Just installed Geomoose... 1st problem
Carlo Pelliconi
c.pelliconi at sis-ter.it
Fri Feb 22 00:22:36 PST 2013
So you suggest to
0. use mapserver as wms server
1. create a new service from the shapefile I need (rendering it not in
agg/png)
2. contact via wms that service, using geomoose as wms client
Is this the flow you suggest?
Il 21/02/2013 18:29, James Klassen ha scritto:
> Use type WMS. Type mapserver is deprecated.
> Also, IIRC the PHP files with Geomoose 2.6 is expecting MapServer 6.
> On Feb 21, 2013 9:48 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it
> <mailto:c.pelliconi at sis-ter.it>> wrote:
> Hi all.
> I've just installed GeoMoose 2.6 over Mapserver 5.6 with
> PHPMapscript on a Debian 6 Squeeze machine with Apache 2.2.16 and
> PHP 5.3.3
> I've a problem with the demo on my machine, in particular with
> <map-sources> of type="mapserver":
> I can't see neither the shape on the map nor the legend with the
> line element in the catalog. Background layers such as google o
> yahoo work good: I can see and navigate them.
> I've configured Mapserver with all the parameters described in the
> documentation (agg, freetype, gdal, and so on: here's my server
> response
> #/usr/lib/cgi-bin/mapserv -v
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Also required PHP extensions are loaded (phpinfo())
> Changing locale_settings.ini for mapserver_url from
> /cgi-bin/mapserv to /usr/lib/cgi-bin/mapserv has no effect
> Maybe I must change the rights of some folders?
> Anyone had the same problem?
> Thanks a lot!
> With Best Regards, Carlo
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
|| SIS.TER || Carlo Pelliconi ||
Certificata (DIN EN) ISO 9001:2000
Reg. n° 44 100 077218
ing. Carlo Pelliconi
Responsabile Sistemi Informativi
* Phone: +39 0542 364034
* Fax: +39 0542 612130
* E-mail: c.pelliconi[AT]sis-ter.it
Sis.ter Srl
Via Mentana, 10
40026 Imola (BO)
C.F/P.IVA 01777271204
ATTENZIONE! I dati contenuti nel testo e negli allegati di questo
messaggio e delle successive risposte sono di natura professionale e
confidenziale, sono riservati esclusivamente ai loro destinatari e
potranno essere conosciuti all'intenro dell'organizzazione del mittente
nel rispoetto della policy aziendale di riferimento. Nel caso queso
messaggio vi fosse giunto per errore Vi invitiamo a cancellarlo e darne
pronta comunicazione al mittente. Ogni ulteriore utilizzo/trattamento è
assolutamente vietato ed inibito senza una formale autorizzazione da
parte del mittente. La non osservanza di quanto sopra indicato deve
considerarsi violazione di legge e può comportare il risarcimento del
danno (art. 2043 c.c.) e la condanna penale di reclusione sino a tre
anni (Art. 616 cp. e 167 d.lg 196/2003).
ATTENTION! The information contained in this message or any of its
attachments may be privileged and confidential and intended for the
exclusive use of the addressee. If you are not the addressee, please
advise the sender immediately by reply e-mail and delete this message
and any attachments without retaining a copy. Any unauthorized
disclosure, reproduction, distribution, or other dissemination of this
information is prohibited. Any abuse would expose the responsible party
to the payment of a compensation (art. 2043 c.c.) and to civil and/or
criminal penalties with jail up till three yaers (Artt. 616 e 167 cp e
d.lg 196/2003).
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/8f623ffc/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/8f623ffc/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/8f623ffc/attachment-0001.jpg>
More information about the Geomoose-users
