[Geomoose-users] Just installed Geomoose... 1st problem
James Klassen
klassen.js at gmail.com
Fri Feb 22 07:57:09 PST 2013
Well 0 and 2 anyway.
You might want to ask on the MapServer list about AGG. I've been using AGG
in MapServer since it was first available and have never seen it say AGG is
available yet refuse to use it. So there is either something funky in your
build of your mapfile (OUTPUTFORMATs messed up). Also, keep in mind
GeoMoose 2.6 was developed against MapServer 6 so you might find some
issues trying to use 5.6.5.
On Feb 22, 2013 2:22 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it> wrote:
> So you suggest to
> 0. use mapserver as wms server
> 1. create a new service from the shapefile I need (rendering it not in
> agg/png)
> 2. contact via wms that service, using geomoose as wms client
> Is this the flow you suggest?
> Il 21/02/2013 18:29, James Klassen ha scritto:
> Use type WMS. Type mapserver is deprecated.
> Also, IIRC the PHP files with Geomoose 2.6 is expecting MapServer 6.
> On Feb 21, 2013 9:48 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it> wrote:
>> Hi all.
>> I've just installed GeoMoose 2.6 over Mapserver 5.6 with PHPMapscript on
>> a Debian 6 Squeeze machine with Apache 2.2.16 and PHP 5.3.3
>> I've a problem with the demo on my machine, in particular with
>> <map-sources> of type="mapserver":
>> I can't see neither the shape on the map nor the legend with the line
>> element in the catalog. Background layers such as google o yahoo work
>> good: I can see and navigate them.
>> I've configured Mapserver with all the parameters described in the
>> documentation (agg, freetype, gdal, and so on: here's my server response
>> #/usr/lib/cgi-bin/mapserv -v
>> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>> Also required PHP extensions are loaded (phpinfo())
>> Changing locale_settings.ini for mapserver_url from /cgi-bin/mapserv to
>> /usr/lib/cgi-bin/mapserv has no effect
>> Maybe I must change the rights of some folders?
>> Anyone had the same problem?
>> Thanks a lot!
>> With Best Regards, Carlo
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> Certificata (DIN EN) ISO 9001:2000
> Reg. n° 44 100 077218 ing. Carlo Pelliconi Responsabile Sistemi
> Informativi * Phone: +39 0542 364034 * Fax: +39 0542 612130 *
> E-mail: c.pelliconi[AT]sis-ter.it
> --------------------------------------------------- Sis.ter Srl Via
> Mentana, 10 40026 Imola (BO) C.F/P.IVA 01777271204
> ATTENZIONE! I dati contenuti nel testo e negli allegati di questo
> messaggio e delle successive risposte sono di natura professionale e
> confidenziale, sono riservati esclusivamente ai loro destinatari e potranno
> essere conosciuti all'intenro dell'organizzazione del mittente nel
> rispoetto della policy aziendale di riferimento. Nel caso queso messaggio
> vi fosse giunto per errore Vi invitiamo a cancellarlo e darne pronta
> comunicazione al mittente. Ogni ulteriore utilizzo/trattamento è
> assolutamente vietato ed inibito senza una formale autorizzazione da parte
> del mittente. La non osservanza di quanto sopra indicato deve considerarsi
> violazione di legge e può comportare il risarcimento del danno (art. 2043
> c.c.) e la condanna penale di reclusione sino a tre anni (Art. 616 cp. e
> 167 d.lg 196/2003).
> ATTENTION! The information contained in this message or any of its
> attachments may be privileged and confidential and intended for the
> exclusive use of the addressee. If you are not the addressee, please advise
> the sender immediately by reply e-mail and delete this message and any
> attachments without retaining a copy. Any unauthorized disclosure,
> reproduction, distribution, or other dissemination of this information is
> prohibited. Any abuse would expose the responsible party to the payment of
> a compensation (art. 2043 c.c.) and to civil and/or criminal penalties with
> jail up till three yaers (Artt. 616 e 167 cp e d.lg 196/2003).
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/3ee458f3/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/3ee458f3/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/3ee458f3/attachment-0003.jpg>
More information about the Geomoose-users
