[Geomoose-users] agg driver
James Klassen klassen.js at gmail.com
Fri Feb 22 08:13:43 PST 2013
I don't know what is wrong with AGG in your particular case, but I would
suggest going with MapServer 6 or newer anyway.
All the installs I have done used a MapServer that was compiled from
source.  Also, the Debian PHP was missing a module (I can't remember which
one right now and it may not be needed anymore for GeoMoose 2.6.  So
rebuilding php from the deb was also necessary.  Duck do you remember???)
http://www.geomoose.org/docs/install_unix.html
Anyway,
apt-get build-dep mapserver
Will pull in all the dependencies and then building MapServer from source
is rather painless.
Also, you can have MapServer 6 and 5.6.5 (or any version) installed on the
same machine if you install to different prefixes.
 On Feb 22, 2013 2:19 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it> wrote:
>  Has anyone installed cgi-mapserver 5.6.5-2+squeeze2 with php5-mapscript
> on debian squeeze with aptitude, and then used with geomoose 2.6?
> I've done, and all seems good (mapserv -v), but in Geomoose It seems not
> recognizing agg driver.
> And now? What's the best way for solving the situation?
> Thank you
> Carlo
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/c56f4083/attachment.html>
More information about the Geomoose-users mailing list
