[Geomoose-users] agg driver
    Carlo Pelliconi
    c.pelliconi at sis-ter.it
    Fri Feb 22 10:13:48 PST 2013
Thank you for you help and your knowledge.
I start trying Mapserver 6.0, available from testing repository.
With Best Regards, Carlo
Il 22/02/2013 17:13, James Klassen ha scritto:
> I don't know what is wrong with AGG in your particular case, but I
> would suggest going with MapServer 6 or newer anyway.
> All the installs I have done used a MapServer that was compiled from
> source.  Also, the Debian PHP was missing a module (I can't remember
> which one right now and it may not be needed anymore for GeoMoose
> 2.6.  So rebuilding php from the deb was also necessary.  Duck do you
> remember???)
> http://www.geomoose.org/docs/install_unix.html
> Anyway,
> apt-get build-dep mapserver
> Will pull in all the dependencies and then building MapServer from
> source is rather painless.
> Also, you can have MapServer 6 and 5.6.5 (or any version) installed on
> the same machine if you install to different prefixes.
> On Feb 22, 2013 2:19 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it
> <mailto:c.pelliconi at sis-ter.it>> wrote:
>     Has anyone installed cgi-mapserver 5.6.5-2+squeeze2 with
>     php5-mapscript on debian squeeze with aptitude, and then used with
>     geomoose 2.6?
>     I've done, and all seems good (mapserv -v), but in Geomoose It
>     seems not recognizing agg driver.
>     And now? What's the best way for solving the situation?
>     Thank you
>     Carlo
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
|| SIS.TER || Carlo Pelliconi ||
	Certificata (DIN EN) ISO 9001:2000
Reg. n° 44 100 077218
ing. Carlo Pelliconi
Responsabile Sistemi Informativi
* Phone: 	+39 0542 364034
* Fax: 	+39 0542 612130
* E-mail: 	c.pelliconi[AT]sis-ter.it
Sis.ter Srl
Via Mentana, 10
40026 Imola (BO)
C.F/P.IVA 01777271204
ATTENZIONE! I dati contenuti nel testo e negli allegati di questo
messaggio e delle successive risposte sono di natura professionale e
confidenziale, sono riservati esclusivamente ai loro destinatari e
potranno essere conosciuti all'intenro dell'organizzazione del mittente
nel rispoetto della policy aziendale di riferimento. Nel caso queso
messaggio vi fosse giunto per errore Vi invitiamo a cancellarlo e darne
pronta comunicazione al mittente. Ogni ulteriore utilizzo/trattamento è
assolutamente vietato ed inibito senza una formale autorizzazione da
parte del mittente. La non osservanza di quanto sopra indicato deve
considerarsi violazione di legge e può comportare il risarcimento del
danno (art. 2043 c.c.) e la condanna penale di reclusione sino a tre
anni (Art. 616 cp. e 167 d.lg 196/2003).
ATTENTION! The information contained in this message or any of its
attachments may be privileged and confidential and intended for the
exclusive use of the addressee. If you are not the addressee, please
advise the sender immediately by reply e-mail and delete this message
and any attachments without retaining a copy. Any unauthorized
disclosure, reproduction, distribution, or other dissemination of this
information is prohibited. Any abuse would expose the responsible party
to the payment of a compensation (art. 2043 c.c.) and to civil and/or
criminal penalties with jail up till three yaers (Artt. 616 e 167 cp e
d.lg 196/2003).
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/738d62e7/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/738d62e7/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/738d62e7/attachment-0001.jpg>
More information about the Geomoose-users
