[Geomoose-users] Postgis layer - point out
Brent Fraser bfraser at geoanalytic.com
Mon Feb 25 09:50:54 PST 2013
Then you need to use the WFS-T protocol (using GeoServer or TinyOWS).
TinyOWS is a WFS-T server now available as an Application through MS4W
(http://www.maptools.org/ms4w/index.phtml?page=downloads.html) and
possibly other packages such as OSGeo4w.
While I did some experimenting with TinyOWS and pre-release GeoMoose 2.6
I wasn't able to finish (I may get back to it soon). In theory, as long
as you store your data in the same coordinate system as your map
display, it should work.
Best Regards,
Brent Fraser
On 2/25/2013 10:30 AM, Carlo Pelliconi wrote:
> Thank you Brent.
> But I need editing capabilities on the postgis layer: is it possible
> in this way (with WMS protocol)?
> Best Regards,
> Carlo Pelliconi
> Il 25/02/2013 18:23, Brent Fraser ha scritto:
>> Configure Mapserver to connect to the PostGIS database and use
>> Mapserver's WMS protocol to communicate with GeoMoose.
>> Best Regards,
>> Brent Fraser
>> On 2/25/2013 10:21 AM, Carlo Pelliconi wrote:
>>> I want to describe in a better way my previous question:
>>> how can I build up a posgis layer in GeoMOOSE WITHOUT using GEOSERVER?
>>> Thank you.
>>> Regards, Carlo
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> || SIS.TER || Carlo Pelliconi ||
> 	Certificata (DIN EN) ISO 9001:2000
> Reg. n° 44 100 077218
> ing. Carlo Pelliconi
> Responsabile Sistemi Informativi
> * Phone: 	+39 0542 364034
> * Fax: 	+39 0542 612130
> * E-mail: 	c.pelliconi[AT]sis-ter.it
> Sis.ter Srl
> Via Mentana, 10
> 40026 Imola (BO)
> C.F/P.IVA 01777271204
> ATTENZIONE! I dati contenuti nel testo e negli allegati di questo
> messaggio e delle successive risposte sono di natura professionale e
> confidenziale, sono riservati esclusivamente ai loro destinatari e
> potranno essere conosciuti all'intenro dell'organizzazione del
> mittente nel rispoetto della policy aziendale di riferimento. Nel caso
> queso messaggio vi fosse giunto per errore Vi invitiamo a cancellarlo
> e darne pronta comunicazione al mittente. Ogni ulteriore
> utilizzo/trattamento è assolutamente vietato ed inibito senza una
> formale autorizzazione da parte del mittente. La non osservanza di
> quanto sopra indicato deve considerarsi violazione di legge e può
> comportare il risarcimento del danno (art. 2043 c.c.) e la condanna
> penale di reclusione sino a tre anni (Art. 616 cp. e 167 d.lg 196/2003).
> ATTENTION! The information contained in this message or any of its
> attachments may be privileged and confidential and intended for the
> exclusive use of the addressee. If you are not the addressee, please
> advise the sender immediately by reply e-mail and delete this message
> and any attachments without retaining a copy. Any unauthorized
> disclosure, reproduction, distribution, or other dissemination of this
> information is prohibited. Any abuse would expose the responsible
> party to the payment of a compensation (art. 2043 c.c.) and to civil
> and/or criminal penalties with jail up till three yaers (Artt. 616 e
> 167 cp e d.lg 196/2003).
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130225/09b8a957/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130225/09b8a957/attachment.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130225/09b8a957/attachment-0001.jpe>
More information about the Geomoose-users mailing list
