[Geomoose-users] Reprojection in PostGIS
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Tue Feb 26 05:45:06 PST 2013
Carlo,
Having POSTGIS in the data stream allows for a lot of flexibility.  I've used POSTGIS quite a bit to convert on the fly during SQL queryies for the most part, so it doesn't really matter what the data is stored as coordinate wise, you can do a SQL query and convert on the fly during a query.
Switching projection inside of a GeoMoose install on the fly is a different matter though (I have seen it done though  :c)
Bobb
>>  -----Original Message-----
>>  From: Carlo Pelliconi [mailto:c.pelliconi at sis-ter.it]
>>  Sent: Tuesday, February 26, 2013 1:08 AM
>>  To: Basques, Bob (CI-StPaul)
>>  Cc: geomoose-users at lists.osgeo.org
>>  Subject: Reprojection in PostGIS
>>  About reprojection in postgis: I've used it in a service with
>>  Mapserver
>>  5.6 (+PHPMapscript+Postgresql 8.4+Postgis 1.5 but without
>>  framework), before upgrading to Mapserver 6 and start using
>>  GeoMOOSE: is this functionality lost with GeoMOOSE? Have I to
>>  store in postgis compulsory with the same projection of the map
>>  project?
>>  Thank you
>>  Carlo Pelliconi
More information about the Geomoose-users mailing list
